Equipment break downs
/ Equipment break downs #1
Oldpath05
Super Member
none
My son ran over a 10" log today and brought his old Army 6x6 to a stand still, a rear end control link come off the rubber bushing mount causing the rear rear end to go sideways and pulled driveshaft apart, then my son come up and got my 40 year old homemade square socket. Well he broke that but that can be expected with a 6' pipe on breaker bar, somethings going to break when just putting a pipe on.
So had to make new square part on square socket, used old piece of truck spring. Then we went down to the log pile. I took the hammer and banged the square lug nut hard, put pipe on bar and banged that hard and finally got the lug nuts to let go and off, pipe works best if hitting socket same time.
Then tried to knock the link arm back on the rubber mount, that didn't work so hooked winch cable on, son lined it up and I put tension on cable then with hammer at same time the link slipped back on, then brought 6x6 up the garage and he welded big washers back on the outer part, they was tacked on before but only can weld so much when theres a rubber mount on the metal pin. These rear end links are most likely original from 65 years ago and I think these square lug nuts are called Bud Wheel Nuts.
Below in middle of pic is the control link thingy
In pic below was first going to try taking the whole link off but after the nut was loose couldn't get a hammer on it to knock it off so put front part back on with help of winch cable...
/ Equipment break downs #3
Least your son had decent place to work and good weather.
/ Equipment break downs #4
Great "make do" lesson but is there a reason for keeping the square lug nuts? Are you planning a restoration? :confused3:
/ Equipment break downs #5
Budd wheels are the worst to change wait till the cone nut comes off the wheel with the outer nut still attached and you need a torch to cut it off.. Or they loosen up and break all the inside studs......
/ Equipment break downs #6
I hate Budd wheels. Do not miss them at all.
Still have the square sockets though.
No more truck wheels for me (I hope)
Change is always expensive, so he uses as is the way it is, all its used for is load and unload wood.
I was wondering if there was square socket for those studs, wonder when the last year was Bud Wheels was installed from factory...
/ Equipment break downs #9
I thought a budd wheel was every not Dayton truck wheel.
Did some repairs on wood slpitter this afternoon with some low/high 10018 stick. I notice on yesterdays repair job the rods would not run smooth and started extra hard and harder to stay lit for some reason, giving off more spatter then usual, well this afternoon it finally dawned on me after getting all upset and ready to throw the rods as far as could. I had my Dialarc on AC and didn't realize it til after I went through a dozen rods.
I didn't know low/high rods would run at all on AC, they didn't on my old Sears AC buzz box, and they wouldn't run at all on my AC/DC Century welder I had 15 years ago unless on DC. But once I moved the lever didn't they run smooth, gee I thought the rods got old if thats possible or somethings wrong with the Miller Dialarc and I had to invest in a green machine....
All this bracket is, is just to hook my bucket teeth on so to quickly-ish move splitter back and forth.
/ Equipment break downs #12
/ Equipment break downs #14
You lost me all ready, gee that was quick............
My truck is a Dayton wheel. The wheel is hollow and the hub is as big as the inside and it’s secured with wedges. They were common 30 years ago and older but not so much anymore. I thought a budd wheel covered the rest of them. Most heavy trucks use a piloted hub which is by far the best option. Some use taper lug nuts like most light vehicles use.IMG_9093.JPG
/ Equipment break downs #15
My truck is a Dayton wheel. The wheel is hollow and the hub is as big as the inside and it’s secured with wedges. They were common 30 years ago and older but not so much anymore. I thought a budd wheel covered the rest of them. Most heavy trucks use a piloted hub which is by far the best option. Some use taper lug nuts like most light vehicles use.View attachment 670333
Its cheaper and faster, less labor to do a brake job on hub piloted wheels....
/ Equipment break downs #16
HUB pilot and STUD pilot
/ Equipment break downs #17
Just taking the wheels off the dayton and putting them back on round is a job. Having to pull the 2-300 pound hubs while spilling oil everywhere and probably ruining the seals in the process is a real treat. There’s definitely a good reason why they’re pretty much obsolete now.
So whats the issues with Bud Wheels, no one likes a square sockets or backwards threads.......... I'm not a fan of split rims they make me nervous putting air in!!!!
/ Equipment break downs #19
Back in the day when I was around semis and cranes we kept the attached tool in every truck for changing Budd wheels. Many times that tool saved the day but they are somewhat expensive. Ken-Tool Power Wrench Sets for Truck, Farm, Buses, Aircraft, RV's – All Tire Supply
The cranes used Dayton wheels due to less room allowed by the planetary drive on the drivers. They were a good strong system but a pain in the keister to line up on such a big and heavy tire.
/ Equipment break downs #20
Right on!
Skid Steer Trencher (A65640)
Skid Steer...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
2018 Peterbilt 579 (A64127)
2018 Peterbilt 579...
120 Gallon Tank (A64127)
120 Gallon Tank...
Iranch IRET13 Electric Tricycle (A64127)
Iranch IRET13...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
