Metro vs SAE
/ Metro vs SAE #1
Frankenkubota
Elite Member
Carthage NC...Deep in the woods
Kubota MX 5800, SkidPro 4 in 1, Ratchet rake, SkidPro pallet forks
Now that痴 a conversation! Now, try to have a CIVIL OBJECTIVE conversation about it.
My dad had a sign on his desk that said,
don稚 confuse me with the facts, my mind is already made up.
I知 not going to list the many reasons we should be on the metric system except to say, if you don稚 see the benefits you don稚 understand. If you do see the benefits and still don稚 agree, that痴 common, you are among friends.
2 things.....
1 we inherited our measurement system from the English. They don稚 even use it!
2. The metric system is used in 3 or 4 of the most important areas of your life.
A. Military is 100% metric. Rah rah all you patriots.
B. All those pills we take, pharmaceuticals, metric.
C. Go buy a quart of soda pop, oh yea, that痴 called a 2 liter.
D. Booze. When I was a drinker you bought a quart of whiskey. Now, metric. 76631D85-0FC0-4EC7-A4BB-DD261999B608.jpeg
I could go on and on but, I致e been kicking that dead horse for 40 years.
/ Metro vs SAE #2
Too bad metric fasteners are not common between countries. They are all different wrench sizes and thread pitches.
USS and SAE were more common and easily identifiable.
Nowadays you have to grab 3 or 4 different wrenches if you don't want to make multiple trips to the tool box.
/ Metro vs SAE #3
I personally don't care which, but I hate when they use both on the same object or machine. Same for switching between slotted, Phillps, Allen, Hex and Torx.
/ Metro vs SAE #4
Metric is so far superior it’s not even fun. I get pissed almost daily trying to use the SAE system. If it wasn’t already stupid enough go ahead and throw your 10 inch foot engineer scale in the mix.
/ Metro vs SAE #5
There are a std pitch on metric witch all countries are using, fine pitch are not so standardized as UNF. You have DIN, ISO and of course JIS.
DIN is oldest and is quite simple 7,8,10,13,17,19,22,24,27,30 and 32 are the wrench size that are in use. ISO has taken down the size a mm, 19 to 18, 17 to 16 or 15 but not all sizes, mostly the dimension that are most common in production.
/ Metro vs SAE #6
It's not 3/8 it's 9,5 mm and 1/2 is 12,7 ;)
/ Metro vs SAE #7
So what's the problem.... I have a American Car Company, truck, assembled in Canada using Chinese parts.....
I use what ever wrench fits bolt or nut or Allen socket head screw or TORX.....
Just be glad you don't own a British car that uses Withworth....
Dale
/ Metro vs SAE #8
So why is your P metric tire mounted on a 16 inch rim?
Why is your 16mm socket made to fit a 1/2 inch ratchet?
We are supposed to be economizing, and yet, view the truck hp wars.
The US, with the Metric Conversion Act of 1975, was supposed to follow Canada.
And where are we 45 years later? America is kind of clueless with setting policies.
What system are you on in West Uncton ?
/ Metro vs SAE #9
Kubota tractors use several British hydraulic fittings mixed with JIC and SAE. British thread grease zerks too.
/ Metro vs SAE #10
All kidding aside, I agree we should be on the metric system and if metric fasteners aren't common between countries they should be.
/ Metro vs SAE #11
BSP is used everywhere in Europe, the common pipe thread used on water pipes etc is British but it's size is give in metric 1" is called R25 here I live.
/ Metro vs SAE #12
They are the same all over when it comes to thread size and pitch, they are so common that nobody except the US uses pitch on STD metric bolts, all else uses just diameter as the pitch is STD if it's not listed.
/ Metro vs SAE #13
As far back as 40 years ago we had Made in USA carrot packaging machines that had SAE on the main machines and and a mix of metric and SAE on the bag sealing mechanisms.
Small Allen head setscrews are almost impossible to distinguish between the two systems.
/ Metro vs SAE #14
I would say it seems like most of the stuff I work on these days is metric fasteners. This includes vehicles, tractors and small engines. I am a land surveyor and our state DOT went all in on the metric system. That lasted just a few years and they switched back to English. I did a couple of jobs in metric and it was not to bad except leveling. I really struggled with the metric level rod. We had one long term job in design, started in English, changed to metric, changed back to English. That is spending the tax payers money wisely.
/ Metro vs SAE #15
R25 would seem to equate to 25.4 mm to the inch.
/ Metro vs SAE #17
I agree that the metric system has benefits, however not all metric measurements make sense. Specifically, wood volume. The metric system uses a cubic meter as the board volume unit. Not a very friendly or useful measurement for the cabinetmaker.
Doug in SW IA
/ Metro vs SAE #18
Doug in SW IA
Cubic meter? 1000L squarebox doesn't make any sense if you are talking about boards, m or m2 is the usual way. m3 is used for firewood or truckloads of timber.
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
UNUSED JCT 60" CLASS8-8000 LB CAP PALLET FORKS (A65055)
UNUSED JCT 60"...
More info coming soon. (A64557)
More info coming...
2025 JOHN DEERE 333P SKID STEER (A65053)
2025 JOHN DEERE...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A64557)
2008 21 Ft...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2015 FREIGHTLINER...
