Best Chain Option for a Specialty Tractor.
   / Best Chain Option for a Specialty Tractor. #11
I don't think that that type of chain is appropriate for tractors. I'm so old that I go back to the time when most tractors were 2wd, and everyone who had a tractor had chains for the tires. Nobody used that type of chain.
Might want to go back and read the OP carefully. He's wanting to put chains on turf tires for winter use. Those chains would work fine for that.
   / Best Chain Option for a Specialty Tractor. #12
Well... maybe. I admit to some confusion. The photos he posted show a lugged tire on his tractor, so I assumed those are the tires he is using.
What I was referring to is that adv. that shows the discount ladder chains on a variety of lugged tires. It would be nice if the chains stayed in a nice straight line across the tire lugs as shown in the advertising photo, but they don't stay that way. Ladders bend around until they fall into the lug spaces. For small tractor tires an "X" shape rather than a simple ladder works better. The center of the "X" is a larger link or a round ring - both available at hardware stores.
The trick with chains is to make up a pair that fits tightly, and then use one of the various spider bungees to draw them even tighter against the tire. It would be nice if there were still tire shops that made them up for you as used to be common. But not anymore. If you want a good set, I'm afraid you'll have to find an old timer or make them up yourself. Luckily it's simple to do, and one pair lasts a long, long time.
rScotty
   / Best Chain Option for a Specialty Tractor. #13
The photos he posted weren't of his tractor. That's why he said,
Sorry I cant upload a photo from my phone, but it looks like this. Google Image Result for https://nebula.wsimg.com/5c6077efdd57c585259137c71d950593?AccessKeyId=F0C8358C393A3324DE23&disposition=0&alloworigin=1
I do about 95 percent of my work on grass, I keep Turfs on the machine. But some of my work includes work in the woods.
   / Best Chain Option for a Specialty Tractor. #14
Sometimes a thread just drifts as does any conversation. Hopefully some of the value is in the drift - especially when the OP is not following closely. When the thread needs to be specific, we often see the OP continually involved. I think that at this point the OP probably has enough information now to answer his original question. And maybe we have raised some associated tire chain thoughts that we can explore as well.
rScotty
   / Best Chain Option for a Specialty Tractor. #15
Ring chains can be problematic because they can get too much of a grip. i had a skidder where the guys ran the chains too lose on ring chains, and the tire spun inside the chains that were getting too much bite. That can really damage your tires!
   / Best Chain Option for a Specialty Tractor. #16
I don't think that that type of chain is appropriate for tractors. I'm so old that I go back to the time when most tractors were 2wd, and everyone who had a tractor had chains for the tires. Nobody used that type of chain. You use a diamond pattern that stands above the lugs, not a radial pattern chain that drops down between the lugs. It just doesn't work with ag (R1) or industrial tires (R4). It can't work if it it drops below the lugs.
In fairness, those type of chains are cheap, easy to put on, and easy to modify to fit a tire. I'm sure they work on smooth surface tires like turf (R3) tires or automotive tires. But they don't work on most tractor tires. Use real tractor chains instead and you'll be surprised how well they work.
rScotty
Note the OP stated he primarily uses turf tires and wants to avoid changing to AG tires. Thus using turf tires auto chains might be cheaper solution!
thanks guys for the responses! I would have never considered a rough ride. I will check out some auto chains.
   / Best Chain Option for a Specialty Tractor. #18
No where did I see a mention of your tire size,
I did see that you are running turf tires.
Have you looked at atv tire chains in the correct diameter and width.
I would recommend the diamond pattern chains;
ATV Tire Chains | UTV Tire Chains | Free US Shipping
The diamond pattern studded or not will provide the most uniform traction with out the grab-slip of 2 or 4 link spaced chains.
Also most chains in low speed applications do not need to be super tight.
I have not used chains on a walk behind tractor, but I have used them on 2wd, 4wd trucks and tractors and cars and side by sides.
And I have used the old big double ring, 2 and 4 link spaced twisted street chains with and without V bar reinforcement, now I have gone with the square or diamond pattern studded chain for normal everyday use of chains nothing will come close to the traction they provide with a high ride comfort. No one that I know of that has tried them has any desire to go back to conventional chains.
   / Best Chain Option for a Specialty Tractor. #19
When I had a smaller 4WD tractor I used V-bar ladder chains. They provided more than adequate traction on ice & snow. I got front & rear tractor chains at the local tire store - Les Schwab. They were exceedingly heavy chains and not a whole lot of fun to instal. As I remember - both pair together, less than $500.
   / Best Chain Option for a Specialty Tractor. #20
We used chains on our Gravely year round because it had turf-like tires. The chains were very similar to the 2-Link HD Twisted listed in the links above. They helped a lot for garden work and mud.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
