Huge haystacks in the 1950's
/ Huge haystacks in the 1950's #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
/ Huge haystacks in the 1950's #2
That's interesting. I always wondered how they got those hay stacks that high. Pretty rare footage. They were probably the only family with an Iphone back then.
I think it was a Droid. ��
/ Huge haystacks in the 1950's #4
Just think of all the men put out of work when the modern hay baler came out. :(
/ Huge haystacks in the 1950's #5
I am given the privilege of using 3 huge bank barns in return for making hay from the landowners property. They are loose hay barns constructed in the mid-late 1800s. Enormous structures with ridge pole mounted crane system for unloading loose hay. Sad part is I cant really utilize much of these barns except some equipment storage. They work for small bales that I used to make by the tens of thousands. Now with large bales, not much use.
/ Huge haystacks in the 1950's #6
But lots of people became employed by the factories that built those balers :thumbsup:
/ Huge haystacks in the 1950's #7
Indeed interesting thanks for sharing. :thumbsup:
/ Huge haystacks in the 1950's #9
Interesting video. I've been around oats grown for grain/hay all my life but I've never seen oats as tall as those in the beginning of this video. Oats were considerably taller than the rear tires of those J I Case tractors.
/ Huge haystacks in the 1950's #10
Just don't grow em like that anymore.
Though I chose a path of math and science through engineering, I grew up on a tobacco farm and I have that gene in my system. There's just something about a field of ripe grain, whatever it is, being harvested and to make it more intriguing is when the harvest is so large it takes multiple mowers, combines or harvesters running to keep up. Growing up in the southeast, we don't have large fields like the midwest and western states so the mammoth equipment the farmers use out there has always been mystical for me.
/ Huge haystacks in the 1950's #11
stuckmotor, Very interesting......thanks for posting it.
Mike
I'm glad you guys enjoyed the video. About the most excitement we had on the farm growing up was when a crew would come to bale hay and put it in the barn.
/ Huge haystacks in the 1950's #13
The work load increased with the small bales. Only when the bales were too large/heavy to handle by hand did the work required ease up.
Easiest is/was farmhand - stack mover - movable feeding gate for the Stacks.
/ Huge haystacks in the 1950's #14
Great video! The Ninety-six Ranch where that was filmed is just north of me in Paradise Valley. Still going strong today.
/ Huge haystacks in the 1950's #16
Stack Boss... heck of a job :eek:
Needle in a haystack... now I can appreciate that saying a little more
Great great video!
/ Huge haystacks in the 1950's #17
Yes, great video. Not old enough for the stacks, but have put up my share of square bales. All for friends and no money. We used to help each other.
/ Huge haystacks in the 1950's #18
Amazing to me, thank you for posting! Maybe a goofy question, but how do they go about pulling hay from the stack for use?
It's a perfectly sensible question. The link below should take you to an explanation of the old way. Be sure to click the (continue reading) button that lets you read the rest of the article and see the hay knives.
Feeding Loose Hay from an Outside Haystack
One other time when we talked about this, someone explained feeding the loose hay with a loader. If I find the posts, I'll put up a link.
Egon has a hay slide as as his avatar and I think used to build the big stacks. If he comes in he'll probably answer your question before I find the thread.
/ Huge haystacks in the 1950's #20
The longevity of the hay quality in loose stacks varied a lot by geographic area. In Western country where the video was shot it survived very well. Here in the Midwest our humidity is pretty high with a lot more rain days. The loose stacks had to be fed the first year. A lot more hay barns were used here. Even as things evolved to baled hay it was still better to store in a barn.
Growing up we hired out to the neighbors to bale their hay and stack it. The landowner would mow it and rake it. I was the youngest on the hay crew. I started driving the baler tractor when I was 8 years old. One Summer we baled and stacked 10,000 square bales for hire plus our own to feed our livestock.
In this pic I'm 10 years old. Summer of '60. That's my Dad on the wagon. 1959 Ford 641 that we bought new. Pulling an Oliver 60T baler that we bought new. We were a well organized crew. Mid afternoon sometimes I'd get very sleepy running the tractor. Dad would flag me to stop. Have me shut the tractor off and sit in the shade leaning against the rear tire and take a nap. He smoked then and rolled his own. He'd have a cigarette and let me sleep a few minutes then we'd get back to work.
Good times. Hard, hot, dirty work. I never noticed. Knew nothing different. People would sometimes question Dad about having me running the tractor that young. After they'd watch me run it a day they had nothing but praise. My Dad taught me well.
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
SET OF (10) ACE CATTLE PANELS W/CONNECTING JOINTS (A60736)
SET OF (10) ACE...
Case 950 8 Row Air Planter (A61307)
Case 950 8 Row Air...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
TANK MANIFOLD (A58214)
Set 4 - 10-16.5 tires on wheels for bobcat (A61567)
Set 4 - 10-16.5...
Here are some similar links:
