   / Share Pics of People Hauling or Towing Something Wrong #13,111
Dad is borrowing the Ford, Kubota and Iron Bull for a couple days to do a French drain at his buddies daughters house. It must be nice to be retired and have all the time in the world to play tractor.... I have to go to work to pay for the toys View attachment 669762View attachment 669763 20200915_190056.jpg20200915_190108.jpg20200915_190124.jpg
   / Share Pics of People Hauling or Towing Something Wrong #13,112
Rock crawler that setup is all wrong, it is chained down way to good. Next thing your going to say is the trailer brakes work and it has lights.
   / Share Pics of People Hauling or Towing Something Wrong #13,113
It's a 2019 Iron Bull 22' 14K gross, 2 x 7k axles, all LED lighting, optional upgraded larger and heavier load tires... But I didn't do disk brakes... Just the standard lame 4 electric drums.
The rear has 2 x 3,300 work load / 10K break load straps, the front is grade 70 3/8" chain (6,600 work load, 26K break). The tractor is around 4,600 lbs as it sits with loaded tires, hoe and loader.
   / Share Pics of People Hauling or Towing Something Wrong #13,114
I’d reverse your tie down equipment. You’ll never accelerate hard enough to break a strap. It could happen with braking or actually hitting something.
   / Share Pics of People Hauling or Towing Something Wrong #13,115
I was just about to say that... if possible I chain down the back and pull it tight then use binders or straps on the front. Not that there's likely to be a problem anyway
   / Share Pics of People Hauling or Towing Something Wrong #13,116
I saw this on FB. That little 3500 pound trailer ( if it’s even that much) definitely isn’t overloaded. IMG_9085.JPG
   / Share Pics of People Hauling or Towing Something Wrong #13,117
It’s probably a yard tractor and not an over the road model. If they didn’t have very much travel in the hitch it’s possible and I wouldn’t be surprised if the crane was automated.
   / Share Pics of People Hauling or Towing Something Wrong #13,119
   / Share Pics of People Hauling or Towing Something Wrong #13,120
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
Hydraulic rail grinder (A56436)
Hydraulic rail...
Air Compressor (New/Unused) (A59225)
Air Compressor...
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
MASSEY FERUSON 204 ALL TERRAIN FORKLIFT (A52708)
MASSEY FERUSON 204...
FORD DEXTER TRACTOR (A52708)
FORD DEXTER...
