Adding aux cooler via the heater engine ports?
   / Adding aux cooler via the heater engine ports? #11
This situation probably won't change any other than buying you some additional time. The extra cooler will just plug up too.
Agree, plus the area between the radiator and the additional cooler will be harder to get at and clean.
That's all I want. If the aux cooler plugs up, then I'm still better off since the OEM radiator hopefully won't be.
Serious question: So the HST hydraulic oil cooler on Kubota HST tractors doesn't work, is harder to clean, won't make any difference or.... what? Has someone informed Kubota of this?
Actually, it's not a serious question: it's rhetorical.
   / Adding aux cooler via the heater engine ports? #14
Why are you even asking advice on this, you have your mind made up do what you want.
Posts #3, #4, #6 and #10, it shouldn't be hard to figure out.
   / Adding aux cooler via the heater engine ports? #16
If I decide to add a small ball valve, which end would you put it on?
And thanks for telling me that. Don't know how it affects the cooling, if any, but I appreciate it.
Put the valve where it is convenient to use. If you are planning on one valve, placement is immaterial.
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2023 Chevrolet Tahoe SUV (A55853)
2023 Chevrolet...
2025 Spirit 48V 1000W All Terrain Electric Bicycle (A55853)
2025 Spirit 48V...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2008 Isuzu NPR-HD Landscape Dump Truck (A56858)
2008 Isuzu NPR-HD...
