Adding aux cooler via the heater engine ports?
   / Adding aux cooler via the heater engine ports? #11
This situation probably won't change any other than buying you some additional time. The extra cooler will just plug up too.
Agree, plus the area between the radiator and the additional cooler will be harder to get at and clean.
That's all I want. If the aux cooler plugs up, then I'm still better off since the OEM radiator hopefully won't be.
Serious question: So the HST hydraulic oil cooler on Kubota HST tractors doesn't work, is harder to clean, won't make any difference or.... what? Has someone informed Kubota of this?
Actually, it's not a serious question: it's rhetorical.
   / Adding aux cooler via the heater engine ports? #14
Why are you even asking advice on this, you have your mind made up do what you want.
Posts #3, #4, #6 and #10, it shouldn't be hard to figure out.
   / Adding aux cooler via the heater engine ports? #16
If I decide to add a small ball valve, which end would you put it on?
And thanks for telling me that. Don't know how it affects the cooling, if any, but I appreciate it.
Put the valve where it is convenient to use. If you are planning on one valve, placement is immaterial.
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
