I often use the 10,000 pounds of ballast weight on the 3 point when I am trying to demonstrate to an "unbeliever" that putting weight on the 3pt. REALLY DOES unload and take weight off of the front axle. This concept will still be debated by some people that cannot wrap their head around the concept that a tractor is a teeter totter with two fulcrum points. The front axle and the rear axle.
So put 10,000 pounds of weight behind the rear axle and tell me the front axle won't lift skyward.
But if you just put a 1000 pounds out back, many will erroneously debate that it doesn't remove even a pound of pressure on the front axle. They cannot see it, but the 10,000 pound example will usually get them to thinking. Another absurd example is to put a 100 foot boom pole on the 3 point and then put 100 pounds of weight at the end of the 100 foot boom pole. Think about that one for a bit. Yes, using absurdity to explain the logical, can work to enlighten.
