Chipper What happens if I hook up too much HP to a Woodland Mills Chipper?
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #11
I always use extremes also when I am thinking a project through. it helps me visualise what is happening. and makes it easier to spot mistakes with dimensional factors.
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #12
True, but there shouldn稚 be an increase of damaging the chipper.
Agreed, but the post I was quoting was so general, it just needed to be corrected.
Using a chipper, other than when first starting out, a bigger hp tractor shouldn't be a problem. You just have to be carful not to engage the pto too forcefully.
SR
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #13
I often use the 10,000 pounds of ballast weight on the 3 point when I am trying to demonstrate to an "unbeliever" that putting weight on the 3pt. REALLY DOES unload and take weight off of the front axle. This concept will still be debated by some people that cannot wrap their head around the concept that a tractor is a teeter totter with two fulcrum points. The front axle and the rear axle.
So put 10,000 pounds of weight behind the rear axle and tell me the front axle won't lift skyward. :) But if you just put a 1000 pounds out back, many will erroneously debate that it doesn't remove even a pound of pressure on the front axle. They cannot see it, but the 10,000 pound example will usually get them to thinking. Another absurd example is to put a 100 foot boom pole on the 3 point and then put 100 pounds of weight at the end of the 100 foot boom pole. Think about that one for a bit. Yes, using absurdity to explain the logical, can work to enlighten.
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #14
I THINK MOST TRACTORS WILL GIVE YOU AN ENGINE PRM --ON TACH-- TO ACHIEVE THE CORRECT PTO SPEED--540 OR 1000. IF YOU RUN THE TRACTOR AT THAT RPM, IT SHOULDN'T MAKE ANY DIFFERENCE WHAT THE HORSE POWER IS AS LONG AS IT'S BIG ENOUGH. IMO
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #15
When I overload the chipper shredder with tops or fibrous material while driving with the 15 hp tractor, the tractor engine bogs.
When the overloading occurs when the chipper shredder is being driven by the 35 hp tractor, the duplex drive belt slips (squeals and smokes to get my attention in doing so)
Sort of an overload slip clutch with a short service life ;-)
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #16
My PTO engagement lever on my M6040 can be feathered. So with the tractor at idle - no problem getting the chipper spinning. This is the DIRECT opposite of the PTO on my JD riding mower. JD is electro-mechanical. It's either on or off. Pull the button - you are 100% engaged. No slipping, no feathering, no easing into rotation.
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #17
I have wondered about this and understand the argument that the shear pin should do its job regardless of HP used. I still have this nagging thought that some excess power or jolt is going to ‘slip through’ before the pin shears. Electrical fuses and surge suppressors come to mind. A 1 million volt lightening strike isn’t going to be stopped by a little fuse or small UPS. (extreme example).
Call me daft but I still will not allow my nephew to borrow my 65 HP rated 5 ft Bush hog to use on his 100 HP JD. :)
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #18
I was going to let this go but I can't help myself.
The question isn't if that scenario will take weight off the front axle, it's when will it take weight off the front axle and when will it add weight to the front axle? Use your scenario but add an additional 20,000 lbs. to the bucket. The fulcrum just changed from the back axle to the front axle and your 10,000 lbs. on the back added to the weight now on the front axle. But we all know it is absurd to think anyone would ever actually put any amount of load in the bucket of their tractor. :D
Back to your regularly scheduled program.
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #19
I see your 20,000 lbs in the bucket, and to keep those rears on the ground I raise you 30,000 lbs on the 3pt. Now your stinking 20,000 lbs is up in the air... :) And I may break out the 100 foot boom pole too... :D
   / What happens if I hook up too much HP to a Woodland Mills Chipper? #20
Whoops.. Our tractor chassis just exploded in a hail of cast iron. :shocked:
Forklift (A56857)
Forklift (A56857)
UNUSED MOTOR OF INTERNAL CONCRETE VIBRATOR (A58376)
UNUSED MOTOR OF...
SDLanch SDLGC100 Crew Electric Golf Cart (A57149)
SDLanch SDLGC100...
2018 International DuraStar 4300 18ft. Reefer Box Truck (A56858)
2018 International...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
UNUSED IRGC40 Battery Powered Mini Golf Cart (A55272)
UNUSED IRGC40...
