Kubota "Shockless Ride", SoftDrive or equivalent accumulator?
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #31
Does anyone have a installation instructions manual for the 1954 loader KSR kit? Plumbing diagram?
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #32
I mow with my bucket removed but i leave the FEL arms on the tractor, it does bang and slam at times, while this is a good idea, it adds complication, guess ill have to slow down while mowing.
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #33
I would guess that the reason for dual accumulators is that they can be pre-charged with nitrogen to different pressures. The lower pressure one would take the initial load when hitting a "road bump" and the higher pressure one would take the "high end" of the shock. This would be similar to variable rate shock absorbers as well as rubber spring cushions on some road vehicles. {Keeps things from bottoming out}
It's interesting how things like the idea of accumulators to cushion the shock load on FEL's evolve over time. It reminds of running a Deere 7720 combine about 35 years ago, give or take a year or two. There was a large accumulator mounted on the side of the chassis that I noticed was connected to the header lift cylinders with a manual valve in between. I figured that had to be cushion for the header so opened the valve one day to give it a try. I was amazed at the effect, it acted like a giant counterbalance spring cushioning the header. (platform as some call it) Not only that but when crossing terraces even at an angle it would prevent on end of the sickle from gouging and picking up dirt due to the balanced floating action.
Nowadays, of course, the newer combines have automated all of this and the operator can electronically dial in the amount of pressure the header exerts on the ground. Also the headers have built-in flex for cutting "on the ground" for short crops such as soybeans. (All at a price of course) The new Deere X9 combines are approaching one million dollars when fully equipped for field operation.
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #34
One thing about dual accumulators. It's either connected in series for extra volume or I've seen one connected to extending side of the cylinder and other to the retract side of the cylinder. The theory is that prevents hose collapsing and pulling the rubber inside on the retract side, when the accumulators are only connected to the extending side.
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #35
Good info.
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #36
I’m trying to fit a 1954 loader KSR kit to a TL1350 loader on a M59.
From Messicks I can see the parts diagram. Two different charged accumulators. Mounted inside the structural lower tubes of the the loader bracket towers. Connected with hoses and metal lines. Then hoses to the loader valve and supplied manual valves for the KSR. The KSR valves are linked together to operate together, on or off.
I first thought the accumulators were connected together for more range. But why the two valves? ptsg May be right, one for extension side and one for retraction side? Problem is I can’t see the flow pathway thru the loader valve or the KSR valves from a parts diagram. Collapsing rubber doesn’t sound good.
I got the KSR kit mainly for just the accumulators knowing the brackets and hoses would not fit my loader.
Not interested having additional lines under the tractor or having to dismount the tractor to turn the KSR on or off.
So far looking at a mounting area right side, inside the loader frame and engine. Building off the third function valve cover box. The accumulators are teed together, needle valve for flow control and damping, ball valve for off and on. Can reach the ball valve from the operator station. Then a line teed to the lift port of the loader cylinder. Haven’t installed it yet. Still in the thinking/mockup mode.
Aftermarket soft ride systems use one accumulator similarly plumbed with good effect.
There is probably an orifice plate needed somewhere. The bouncing load energy is stored and released by the spring-like action of the accumulators. An orifice would help dampen the force and convert some of the mechanical energy into heat. Thinking needle valve would give an adjustable orifice-like flow control.
I’m not in a hurry and taking time to gather information and consider design issues before installing. Whole lot more I don’t know than understand at this point. Any advise will be welcome.
What I know so far;
The accumulators are precharged to 290psi on one and 580psi on the other. Made by Bosch. Threads British straight with O-ring similar to SAE type. Needed a good hydraulic shop to figure that out.
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #37
The ones I've seen are pre-charged with 40 Bar or 580 PSI.
If you're doing your own kit, you can simply add a 12v Solenoid shut off valve instead of a manual shut off valve. Run the wires to the cab, with a switch and you're good to.
I've thought about adding this soft ride feature to my homemade loader as I road the tractor quite often. It would cost me less than 100€ ($120) for the pre-charged accumulator, hoses, fittings and manual valve. But haven't go around to do it yet.
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #38
At first I thought about using a solenoid valve. Mounting placement I could use either and maybe could throttle a manual valve. In a position I can reach. Needed about 2” height for my mockup so adding a needle valve for flow control was a solution. Trying to keep simple. Users of KSR have reported infrequent need of turning off.
Your point of maybe needing accumulators on each side of the cylinder is interesting. To give cushion on one side would produce vacuum on the other. I could do that too. Would require two valves to turn off or on.
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #39
Any safety issues to consider with the KSR other than those normally associated with charged accumulators?
Edit: Talks about the reason for two accumulators:
W.R. Long, Inc. | Comfort Ride
   / Kubota "Shockless Ride", SoftDrive or equivalent accumulator? #40
I知 trying to fit a 1954 loader KSR kit to a TL1350 loader on a M59.
I first thought the accumulators were connected together for more range. But why the two valves? ptsg May be right, one for extension side and one for retraction side? Problem is I can稚 see the flow pathway thru the loader valve or the KSR valves from a parts diagram. Collapsing rubber doesn稚 sound good.
So far looking at a mounting area right side, inside the loader frame and engine. Building off the third function valve cover box. The accumulators are teed together, needle valve for flow control and damping, ball valve for off and on. Can reach the ball valve from the operator station. Then a line teed to the lift port of the loader cylinder. Haven稚 installed it yet. Still in the thinking/mockup mode.
I知 not in a hurry and taking time to gather information and consider design issues before installing. Whole lot more I don稚 know than understand at this point. Any advise will be welcome.
What I know so far;
OK....SmokeyDog and I started talking and we've ended up with the exact same kit which we plan to put on our Kubota M59s. Somehow, neither one of us ended up with a copy of Kubota's formal installation instructions that was supposed to come with this kit. So if anyone has that literature it would be helpful. Otherwise we plan to just put our heads together and figure it out.
We've both got a good mechanical background, but I'm laid up right now and will probably be another 6 months before I can get back into the machine shop or to tractoring. Right now it falls to SmokeyDog & I'm just going to have to follow along while he has most of the fun.
On tractors with heavy loaders and buckets having a way to reduce the bouncing with a hydraulic "Comfort Ride" is real valuable.
We all know that not only does some damping make traveling more comfortable, but it really reduces the impact loading of the bounce on the front end and loader parts. I've seen these dampers put to good use on tractors from about 35 to 100 hp. We have it as a factory kit on our 90 hp JD.
For some reason there are a large number of these Kubota "Shockless Ride" or "Easy Ride" Kits out there on aftermarket and on Ebay, and they all work more or less the same. Prices are good.... maybe as low as half the asking price. So there's a good opportunity here for anyone else who wants to join in the fun. You can't loose much, or hurt much of anything, and it may just work a treat.
rScotty
2014 Ford F-150 Crew Cab 4X4 Pickup Truck (A55852)
2014 Ford F-150...
UNUSED GRASSROOTS IMPLEMENT 4' BOX BLADE (A57192)
UNUSED GRASSROOTS...
CAT Quick Attach Forks (A56469)
CAT Quick Attach...
UNUSED FUTURE RB66-66" ROCK BUCKET (A57193)
UNUSED FUTURE...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
UNUSED FUTURE BF47 47" PRONG BALE FORKS (A57193)
UNUSED FUTURE BF47...
