Kubota part # symbol meaning??
/ Kubota part # symbol meaning?? #1
Shopmaster
Member
Midwest, US
1995 Kubota L2500DT
I知 replacing the big oil seal on top of the front axle case of my 1995 L2500DT. The instruction sheet with the seal says fits serial numbers ~ 61008. My serial number is - 54870.
So what the heck does ~ mean? I get > greater than | < less than. But what exactly does ~ mean?
/ Kubota part # symbol meaning?? #2
The symbol means around. Hmmm. Deere will put a - after a serial to indicate greater than. IE 10000- means serials greater than that . -10000 means less than. Likely the same meaning.
Yeah, hmmm..... It’s a pretty good job to get at the seal and I hate to make a go at it only to find ~ means not happening this weekend. But there are no other valid part numbers for this thing. All older numbers have superseded to this apparently.
I'm going to go ahead and yank everything apart this weekend and hope ~ doesn't bite me in the rear! :eek:
/ Kubota part # symbol meaning?? #5
If it makes you feel any better, the Messicks parts illustration drills down to the part number you have without any serial number breaks. Previous superceded part numbers do specify a serial number issue, but only advise to call prior to ordering. Those superceded numbers also are noted as not for sale, or something to that effect. That's how I read it anyway! I don't know about the ~ symbol.
Good luck with the repair.
/ Kubota part # symbol meaning?? #6
It means they don't have precise build records for the part and to double check comparing old to new before installation
Well, it fit. New design so hopefully it'll last. Kind of a pain, but not that bad in the grand scheme of things.
2019 Ford Transit Cutaway Shuttle Bus (A66736)
2019 Ford Transit...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
PALLET OF ALUMINUM PIPING (A68842)
PALLET OF ALUMINUM...
Gravely Pro-Turn 148 50in Zero Turn Commercial Mower (A66734)
Gravely Pro-Turn...
