rear work light wires for TC45DA
   / rear work light wires for TC45DA #11
According to the wiring diagram is is powered off of fuse #7 and the front lamp relay #9, which is powered when the key is on. The switch for the light was on the light itself.
   / rear work light wires for TC45DA #12
Thanks. I just checked the plug with the ignition and lights on and I'm getting nothing. Looks like I have to do some electrical troubleshooting now. I'll start by checking the fuse. The plug has been behind the seat exposed to the elements for 15 years, so maybe the fuse cooked at some point. NH should have spent two cents and put on cover on the plug if they were going to leave it zip tied to the wiring harness out in the open. Already had to clean it with contact cleaner to get the crud out of the female prong of the plug.
PS: Yep, #7 fuse was cooked. I hadn't even noticed that the forward work lights were not working. Replaced the fuse and now I have the forward work lights back and power to the rear work light plug.
CATERPILLAR 272D3 XE SKID STEER (A52706)
CATERPILLAR 272D3...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A55851)
1996 JLG Commander...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2020 FREIGHTLINER...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
