NX5010 Trouble with Safety Switches
   / NX5010 Trouble with Safety Switches #1
sierrakioti
NX5010
Not my first tractor or Kioti, but this NX5010 Cab (manual) is new (less than 50 hrs). Hopped in after a few days off of the tractor and found that the key would not engage the starter. Various troubleshooting has the issue nailed down to one of the safety relays not allowing for start.
- If I jump the starter solenoid and positive terminal, tractor starts and runs.
- I've tried jumping the safety wires at these points: behind the seat (seat safety), behind the clutch piston switch (clutch safety). No change. Brake and neutral safety I hear strong relay clicks, so have not jumped these two points.
- With the key on:
- when I put the primary gear selector in neutral I hear a relay click.
- when I put the brake on I hear a relay click.
- if I operate the clutch piston switch or depress clutch pedal, I don't hear a relay.
- if I bounce, stand up, or sit down on the seat, I don't hear a relay.
- both of the above are true whether I jump the two wires or leave them wired correctly
The clutch plunger switch wires go up to a pigtail fitting and then to some kind additional sealed 'something'. If I disconnect and reconnect the pigtail connector I get a lot of relay clicking... it seems this does more than just send the clutch safety signal.
Any ideas for further troubleshooting? I am in touch with the dealer, but am a distance away, and like to figure out how to chase these issues down myself.
Thanks all!
   / NX5010 Trouble with Safety Switches #2
follow the wiring diagram. if you have been in touch with the dealer I am assuming you asked for them to send a diagram to you?
   / NX5010 Trouble with Safety Switches #3
Based upon your initial description I’m not convinced that any of the safety switches are at fault yet, but if you are, then disregard this reply.
Have you completely tested the key switch? It has been problematic for some people. Here is the test procedure for the key switch:
   / NX5010 Trouble with Safety Switches #4
Are the brake pedals locked together. My NX6010 has a switch on the tab that locks the two pedals together.
Good suggestions! Yes, brake pedals are locked together and that switch looks to be aligned properly.
Very good suggestion on the ignition switch. Unfortunately, continuity checks out and it appear to work as designed.
   / NX5010 Trouble with Safety Switches #6
Have you checked that the main PTO switch is not engaged?
Also have u tested the engine start relay? (Procedure below)
   / NX5010 Trouble with Safety Switches #7
Betcha it is something silly like a nuetral safety switch check the range and power shuttle by "rattling them" while the key is switched to start.
My Mercury remote control box on my pontoon has that issue.
Appreciate the suggestions, especially AWSubie with the workshop manual scans. I've tested all of the above with no love. Dealer suspects that it is a faulty relay control box (inside 'driver side' rear interior fender panel), they've seen a few low hour tractors with this issue. They are sending a new one and I will swap it out.
I'll close the thread with an update it that sucker works!
Closing out this thread:
Well, that was a lot of troubleshooting for simple fix: turns out the safety switch module was faulty. Dealer sent me a replacement safety switch module and a quick swap solved the problem immediately. This is the small black box on the 'driver' side fender panel behind the seat (on NX5010 Cab).
Dealer says they've had this issue on several lower hour tractors recently. The module looks slightly different with a color 'filler' resin the new one red, the old one black.
Thanks everyone for their help. I did get to learn more about the tractor and what to troubleshoot in the future around starting problems.
   / NX5010 Trouble with Safety Switches #10
Well, my 2020 production NX6010 HST with 47 hours just started doing the exact same thing.
Checked all the safety switches, can't find any problems. Checked key switch with meter, checks out ok. Checked out battery with battery tester (load test) checks out fine. Checked the ground and positive terminals. Checked every harness I could find. With key set to on, I can start it with a jump wire to the starter relay and it runs fine and functions normally, just can't start with switch. I asked my dealer to order me the safety switch module under warranty. My module is dated February 2020 and has the black epoxy filler.
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
GODWIN (INOPERABLE) 3,500 PSI HYD. POWER PACK (A55745)
GODWIN...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2012 CM  T/A ENCLOSED 14 TRAILER (A55745)
2012 CM T/A...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
