Good morning!!!!
   / Good morning!!!! #117,901
Ron good thoughts and well wishes sent
   / Good morning!!!! #117,903
I went out to the shop and started cutting some metal for the welding cart.... then I remembered that I saved the old frame from the gas grill....mmmmm.
Went over to the scrap pile and eyeballed it to see if it would work.... it would surprisingly well...
So, made a frame for around the bottom, welded on the 4" casters, then set the grill frame over and welded those together. Measured for the top frame, cut the angle iron and welded that all together. Painted up all the new metal, letting it dry overnight. The shelves on both ends have notches to hold barbecue tools.... they will work perfectly to hold the torches.
Originally I was going to cut off one of the shelves, but realized I could cut out a circle and use it to hold the Argon tank upright. It's heavy plastic so really easy to do! It's secured from the bottom with big plastic knobs / bolts, so easy to remove for tank changes.
I saved a bunch of time, materials, and was able to repurpose some old scrap.... I still have to clean the shelves up a bit, but will turn out nicer than what I was originally planning. Here's a couple of " in progress" pics.
   / Good morning!!!! #117,904
I’d need more than $2 worth of hose, my filler is on the back fender.
Yep, mine is behind the seat at the level of the armrest... about 5' off the ground... hard to lift and hold that 5 gal can at head level....
   / Good morning!!!! #117,906
Got everything mowed, was just going to do along creek and back hill, and just kept going.
Put riding mower in garage to remove transmission. Had to charge battery some to get it started.
Got trash out to the curb.
Showered and now watching baseball.
   / Good morning!!!! #117,907
Sadamo, my Apple Watch reminded me that today is National Park day! They are giving away awards for walking a mile today (and it does not have to be in a park). Whip and I are going to hit the creek trails as soon as the temp falls below 95˚F to snatch up that award! :drink:
Severed and removed a foot section of 5 big roots from my root barrier trench 100˚F, Arrg. Picked a instant pot full of okra - time to make the gumbo.
   / Good morning!!!! #117,908
69F and "fair" @ 21:00, headed down to a low of 59F apparently.
Got mowing done on compost/wood lot, then removed MMM and put on FEL and box blade and swapped out the bucket for pallet forks and unloaded capstone for retaining wall from van which I forgot was still in there.
Then got cleaned up, loaded up tools, and headed out for hosta removal party. Got almost all of it removed from around their propane tank. There's more there (a lot) if we want it ... along with other stuff.
Came home with a veritable crap load of it ... and a 2' tall ginkgo tree ... :thumbsup:
Hope everyone had a great day.
   / Good morning!!!! #117,909
Good morning to all! A cold front moved across the area last night, cooler weather for the next few days.... by cooler, in the high 80's. Chances of a shower today.
My, my, my, you guys have been busy.... I'm gonna havta up my game....
Shyeah, right ... you da man ... :thumbsup:
RS, sounds like your getting the landscaping project close to wraps...
Not even close ...
you have transplanted a lot of hostas!
Indeed we have ... still miles and miles to go though ... :rolleyes:
Nice repurpose on the grill ... :thumbsup:
   / Good morning!!!! #117,910
... RS, glad your sting is better.
Thanks Kyle.
It's still itching ... I just tried some hydrocortisone cream on, will see if that does anything for it ... :confused3:
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
(INOP) 2012 CATERPILLAR CT660S T/A DUMP TRUCK (A58375)
(INOP) 2012...
UNUSED FUTURE ZWB 59"HYD MINI STRAIGHT DIGGING ARM (A58376)
UNUSED FUTURE ZWB...
MMS MS36C Skid Steer (A57149)
MMS MS36C Skid...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2021 CATERPILLAR 308CR EXCAVATOR (A52709)
2021 CATERPILLAR...
