Buying Advice Tractor for 84" to 96" RFM
   / Tractor for 84" to 96" RFM #1
PsRumors
Gold Member
Cartersville (NW) Georgia
Kubota L45
I am wanting an 84" to 96" rear mount finish mower but need a tractor to run it. I have my L45 for loader and backhoe work but it is down on PTO hp and the loader isn't removable.
Price point, the less expensive the better. $7k is about max. Diesel is highly preferred. 2 wheel drive is fine but power steering is a must. Live PTO, whether true independent or 2 stage clutch. I'd like the tractor to have enough of a low gear to run a tiller.
What tractor would you all recommend?
   / Tractor for 84" to 96" RFM #2
First - look at the spec sheets for the mowers under consideration. What PTO hp do the manufacturers recommend. This will give a good starting point on tractor selection. Second - is your land flat, level & dry. If not - you should consider 4WD. Third - your budget may not be realistic.
35 to 45 pto hp
2wd is fine for my needs
Massey 135, 245, etc can be had for well under $7k
Not looking at new compacts but good tried and true tractors
   / Tractor for 84" to 96" RFM #4
Re: Tractor for 84" to 96" RFM
Here is a really nice Massy 135, fully restored with new tires. I am sure they can ship it to you at a reasonable cost. I think they even have a set of rear remotes.
Pardon Our Interruption
I saw that. And it is nice, but gas. Gas will be the last choice
   / Tractor for 84" to 96" RFM #6
I have a Landpride 72" RFM behind my Kubota M7040.
In reality, I prefer using my Zero Turn and can get more grass cut per hour as so little time is wasted turning.
Dave M7040
   / Tractor for 84" to 96" RFM #7
I ran a Woods RM990 (90 inch) mower for years with a David Brown 885. 42+- PTO hp. Plenty of power.
   / Tractor for 84" to 96" RFM #9
I have a 37hp 4x4 tractor and it's able to pull and run my 84 inch finish mower just fine. It leaves a much nicer cut them my 6ft rotary cutter and it's easier to pull. I don' t have a front loader on it, so when I lift the mower, my front end gets really light. If I'm on flat ground, I'm OK, but if I'm going up hill and I lift the finish mower off of the ground, my tires will become so light that I cannot steer it.
If I was going to buy another tractor just to pull a finish mower that big, I would want something in the 45 hp range. 40 hp should work, but if it's a used tractor, you probably don't have 40 hp any more. For a bigger mower, it would have to be quite a bit bigger tractor.
Since buying my 5ft zero turn, I have not used my rear finish mower behind my tractor. For my nice walking trails, I'll hit them with the rotary cutter if they get out of control, and then go over them with the zero turn. The tires have rotted off of the finish mower, and I'm guessing the belt is probably bad too. It's been quite a few years since I used it. I might sell it, or I might get a bigger tractor and a batwing, and then put the 7ft finish mower on the 37hp tractor permanently for mowing the dam and around my pond.
PALLET TOTE OF MISC HARDWARE (A58374)
PALLET TOTE OF...
Kubota L4701 (A53317)
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
Black Steel Diamond Plate (A55758)
Black Steel...
LOT: (4) Large Wheel Chocks (A59076)
LOT: (4) Large...
flooring (A55758)
flooring (A55758)
