Aluminum Bellhousing ?
/ Aluminum Bellhousing ? #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
I am hearing that some JD's have an aluminum bellhousing and worked hard may crack the bellhousing or bolts may pull out. Any truth to this. hearing this from a used tractor dealer who claims he will not take in a newer JD in the under 75 HP range.
/ Aluminum Bellhousing ? #2
I had heard of a different brand having issues when the tractor also had a hoe attached. I have not heard of the Deere products having those issues in quanity.
/ Aluminum Bellhousing ? #3
As an FYI, no manufacturer will honor a warranty on ANY tractor that has a 3PH style backhoe attached. Has to be a subframe model. Motor vehicles today are almost all aluminum bellhousings and pot metal to boot.
/ Aluminum Bellhousing ? #4
Perkins engines, often used on Massey Fergusons, have had aluminum bellhousing for years...
I got a Perkins 4.108 with an aluminum bellhousing, and it was in production from 1958-1992, with 500,000 engines made.
/ Aluminum Bellhousing ? #5
Motor vehicle bell houses are supported on both ends of the bell housing and don't get the twist and other stress's, like a tractor does.
SR
/ Aluminum Bellhousing ? #6
SR
Not exactly correct. off road vehicles with aluminum bellhousings are subject to twisting, much more so than a tractor where all the drive components (except the front axle) are solid mounted. If you are stressing a bellhousing on a tractor to the failure point, you are twisting the frame and that is abuse.
/ Aluminum Bellhousing ? #7
EVERY vehicle I own has rubber mounts on the motor and tranny.....Bell housing is between.
EVERY tractor I own is mounted solid, no rubber mounts...
SR
/ Aluminum Bellhousing ? #8
SR
Which is even more reason the aluminum bellhousing is good. There is no flex unless it's the frame.
/ Aluminum Bellhousing ? #9
My TC33D had no frame, just the engine/trans castings. I never had a issue but some people did (broke in half), many of those had hoes on them.
/ Aluminum Bellhousing ? #10
Only in your opinion, NOT in mine...
MY farm tractors don't have aluminum bell housing, and that's a good thing!!
SR
/ Aluminum Bellhousing ? #11
/ Aluminum Bellhousing ? #14
Most tractors don’t have a frame and the the casing is the frame.
/ Aluminum Bellhousing ? #15
Tractors with mid mount frt end loaders stress clutch housing when bucket is utilized/loaded without the need to twist the frame by utilizing the fulcrum affect
/ Aluminum Bellhousing ? #16
"irregardless" isn't a word, but I'll let you slide this time! lol
SR
From Merriam & Webster
Frequently Asked Questions About irregardless
Is irregardless a word?
Yes. It may not be a word that you like, or a word that you would use in a term paper, but irregardless certainly is a word. It has been in use for well over 200 years, employed by a large number of people across a wide geographic range and with a consistent meaning. That is why we, and well-nigh every other dictionary of modern English, define this word. Remember that a definition is not an endorsement of a word’s use.
/ Aluminum Bellhousing ? #17
Nothing wrong with aluminum bell housings, they use alloy to help strengthen it. It must be engineered right with the correct reinforcement at the higher stressed points. Truthfully I have seen more fractiures and breaks on cast steel or iron.
The place I dont trust aluminum is where you have fluctuations in temperature that are high to low, like the new high efficiency furnaces and boilers. Cast Iron is much better in those applications.
/ Aluminum Bellhousing ? #18
Most tractors don稚 have a frame and the the casing is the frame.
Yeah except Most of the CUT's being sold today...
I would choose a cast steel/Iron front axle cradle given a choice over a welded up steel structure...
Conversely I would choose a welded up steel support structure for the FEL mount versus cast ones since there have been a few broken castings of this part featured on TBN and when warranty wouldn't cover it they weren't cheap.
Maybe somebody has broken a cast front axle cradle on this site , but i can't remember seeing one.
Have seen a few broken cracked front welded axle cradle and updated versions- along with engine shim kits since the clearances were incorrect on TBN
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A64557)
2006 Sea Ray...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
2019 Ford F-550 Altec AT248F 43ft. Bucket Truck (A64556)
2019 Ford F-550...
