Mower deck belt jumping off again
/ Mower deck belt jumping off again #1
jpilk99
Gold Member
Bolton, MA
1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
Hi folks,
I have a 2011 Husqvarna LGT 24K54 rider and love it ...when it's not giving me fits. And I realize that machines don't give fits, owners who aren't clever enough to keep em' running proper are the issue :).
I had a lengthy post at the end of last season where the mower deck belt kept jumping. Lots of good inputs/questions around pulleys, tensioner, etc. and while I got all new spindles, a new tensioner, certainly new belt(s), I think the issue ended up being that the "pitch" of the deck was not correct. I know the front needs to be 1/8" to 1/2" lower than the rear and ...after addressing that, it seemed to work well. For a while.
Now it's doing it again. I bought a new belt (not OEM) and thinking that was a mistake; either too wide or a bit too long. I checked all bearings/spindles and all seem fine - no slop, same height, etc.
I guess my big question is this: If I start all over with getting on a flat surface, measure height of blades - front to back - off the ground, as well as side to side to make sure she's level, I wonder about where "top dead center" is, or where Husqvarna expects me to start ...ground zero? If I put the deck adjustment at the bottom, what height should things be off the ground? Where is the starting point for that front "arm" that attaches to, and 'lifts' the front of the deck, where should I start with that? I"m wondering if I'm starting TOO HIGH or TOO LOW with that front arm, or the 2 rear arms, to then start measuring the height of the blades, etc.
It's crazy but, I put a new belt on, can see that the front is nicely lower than the rear, (almost a 1/2"), and I can go Maybe 50' before the belt jumps. I do have more success if I mow with the deck high off the ground, but, ...I like a nice flow, low cut, of the grass.
Please help. Thank you!!!
Jay
/ Mower deck belt jumping off again #2
Belt guide pin are bent and out to far from pulley. Could also be broke off and missing.
Thanks so much for quick response, Leejohn. Please forgive my ignorance, but, what is"belt guide pin"? Internet search doesn't show me anything that I see on my deck/tractor. Is it that "arm" bolted to top of pivoting tensioner pulley that ducks down a hole in tensioner arm? I've been wrestling that thing for years. Belt jumps, it gets ...muckled. Bend it back into place, ...belt jumps, it's gets moved. Bought new one, same story.
Thank you!
/ Mower deck belt jumping off again #4
It would be good to link your old post to this. In regards to your leveling question, most times on a Husqvarna deck when you place the front rod in the hole you will have to lift the front of the deck a tad. Set your tire pressure and measure from the blade tip cutting edge in the position that you normally cut in. Reduce the forward pitch to a 1/4" if you are loosing the belt. (587686701) You can raise the deck at its highest setting to where you are below the frame by at least 1/4" if you wish. It would be nice to know which pulley the belt comes off. Coming off in 50'- there is something definitely wrong with the deck. I've added an extra guide at times for those that loose the deck at the tensioner. Just buy the same guide and mount it where you think the belt would PUSH off. Think not of the engine pulling the belt through the pulleys, but of it pushing the belt through. That change in mindset helps solve these kind of issues.
Thanks Tom.
Here's the link to the previous post: https://www.tractorbynet.com/forums...127-brand-new-mower-deck-belt.html?highlight=
When you say to "measure the blade tip cutting edge in the position that you normally cut in", there isn't enough room to get under the deck and measure :). Don't understand your other comment about "You can raise the deck at its highest setting to where you are below the frame by at least 1/4" if you wish".
I would say it's jumping off at that tensioner pulley with the guide on it, because there's where it seems to be all bungled-up after jumping.
Interesting, your initial comment about "you will have to lift the front of the deck a tad" after placing the front rod in the hole - I don't have to do that, so obviously that means the rod is too long, and I need to shorten.
/ Mower deck belt jumping off again #6
A common complaint that I hear is not being able to cut high enough. Over all HOC is limited by tire pressure (14 front 10 rear is common), how far the rear of the deck can go and the amount of pitch. It is apparent by your comment on leveling that that isn't a concern of yours. So yes, raise the deck where you can work with it. Remember that if you are cutting very low, grabbing a high spot with a blade momentarily slows belt travel at that spindle. Remember that the deck is not only wide, it is deep to where the front of the center blade to the rear of a side blade creates a big triangle. Tilt that triangle forward from an increased pitch it seems to exaggerate itself. Remember the rear doesn't change. It is common with the single rod suspension in the front that the little bracket under the axle gets bent increasing the pitch. Especially with more deck for weight and width to hit something with.
I'm still thinking something is askew here due to how quickly it comes off. This is one of the few decks that I work on that have such a great deck belt life that the belt can run practically the life of the tractor. Be sure that your anti sway bar is on in the rear, that your center arms are secured at the rear deck brackets and not coming loose.
How do you "add extra guides for those that loose the deck at the tensioner"?
/ Mower deck belt jumping off again #8
jpik
It's idler bounce. As you say, it only happens when you are mowing in the lower setting, thus placing more force on the belt. As the blades engage the grass and/or some heavy clumps of grass, the belt stretches and then when the load is less, the belt relaxes. This will cause the idler to bounce as at one moment the belt is longer and then the next moment the belt is sorter so the idler has to move to accommodate this change in belt length.
As Tom has said, extra guides will help, but the real reason is idler bounce.
A stronger spring will help, and frankly I'm surprised that you are balking at getting a new spring, with all the issues you are having.
Some kind of shock absorber is required to limit the idler bounce. Actually the idler should never move away from the normal position. Yes it can go in to tighten the belt, but is should never move out to make the belt loose.
Here is my suggestion. Find a way to put a piece of rubber that has some give to it, say a cut out piece of bicycle tire. Bolt the rubber piece in position so it is just touching or at the most a 1/4" away from the idler arm when in the normal position. Just to make this a little clearer, the rubber piece should be positioned so that the idler arm will be limited in it's movement to make the belt loose.
If you had a high speed camera, you would not believe how much the idler pulley moves. And what causes the idler arm to move, belt stretch.
Richard
jpik
Richard
Thanks VERY MUCH Richard. Great inputs/ideas.
Not sure where - how - you got some impression I'm averse or "balking" at getting a new spring. I'll buy a new spring tonight. That makes a lot of sense. (I actually bought a brand new spring at the end of last season... Just remembered that when I went out to take a picture of the deck).
I'm pretty sure I bought a new idler arm "setup", the pivot-arm and the pulley that moves in and out. i have a new spring and 'retaining arm' coming soon.
Very interesting comment about keeping the belt loose - I would have thought the exact opposite, keep belt taught/tight so that it doesn't jump, but, you make a great point about when the blades engage thick grass, belt tightens, blades then spin free and belt loosens ...
Almost seems like I should try and have that pulley that adjusts forward, pivoting on the tensioner arm, to stay "back" ...so that the belt stays loose, right? Just don't know how to do that. Where were you thinking I'd bolt the piece of rubber (see attached photo). Why not just use a ...softer spring? Just scared about this because, if I throw my BRAND NEW belt, it will stretch and become closer to junk. I've bought probably 3 or 4 belts in the last few months... :-(
I wonder if I ...leaned on the idler arm and try to bend it up a little?
/ Mower deck belt jumping off again #11
Belt problems usually are caused by either pinch points on one of the pulleys or high points on the inner part of the pulley. These will cause thrown belts and/or will "eat" belts.
Look at your pulleys carefully all the way around inside.
Ralph
/ Mower deck belt jumping off again #12
Below is my marked up drawing of your JPG. I noticed that in your photo, the belt guide that would normally be installed on the tensioner pulley is not in place. I assume that you put that in after installing belt on the deck.
Do you have this item, number 9 in the photo below, attached to your engine?
The belt that is used on your mower is long. Power pulses from the engine and load variations from the mower blades can cause the belt to stretch and then relax. This will cause the belt tensioner to move around a lot. It only takes one loose moment for the belt to jump off one of the pulleys.
Richard
Ralph
Good thought. I checked (only with naked eye) and they look fine. Thank you though.
Richard
Great notes/graphics overlayed on my JPG. Yes, I have part #9. Yes, I have my belt guide on the tensioner - just not in the picture. And Now I understand how to setup the additional guide with the rubber stopper - I'll get right on that. Thank you.
Richard
Richard. I mowed yesterday with NO JUMPING. Not really sure why, but, I did take the tensioner arm off, clean everything, actually removed the old washer and put a rubber one in it's place (don't ask - I thought it would take the tiny bit of slop out of the arm) and then I did bend the arm up, with the pulley that you noted "moves with the belt", just a little so that it was ...reaching up toward the engine/drive pulley. I also did not lower the deck below 4.
I'm going to setup that rubber so that the tensioner arm can't ...over extend itself. Thanks so much!
Richard
Re-posting here on this subject as my belt jumped the other day. When I stopped to inspect, I saw that the "tensioner arm restrictor post/arm/thang" was bent over pretty well, which - to me - means that that tensioner arm/pulley REALLY got yanked on. What's odd is that I was mowing on flat grass and didn't hit anything. Pretty confusing.
So I straightened out that "restrictor thang" (which I believe has been a godsend) and put another belt on, (the one that jumped was cut up a bit), and it seems to be running fine. But I held my iphone down while mowing to try and video the belt as it goes around. And while this short youtube clip of it ain't the greatest, and it's off kilter, it sure looks - to me - like that belt if ...floppin' around a fair amount and I'm hoping others can comment on if it appears to be acting normally or, indeed, it's kinda loose. Here's the link to the video and thanks in advance for any comments:
Jayt
/ Mower deck belt jumping off again #18
Can't really comment on what you've done so far but I'll say that I had this exact problem before. Turned out to be a very small piece of twig that got wedged in the groove of one of the pulleys. Almost couldn't see it but I could feel it. My belt would jump around like that and everything would work for a while but eventually toss the belt. I'll add that in many hundreds of hours of extremely hard use I've never thrown a belt any other time so I wouldn't think a deck being slightly out of alignment would cause this but who knows. You may have done this already but I would triple check all those pulleys. Don't just look, feel each one all the way around. If you have one that's bent, or one with some small object wedged in there someplace, it would definitely cause what you're seeing.
I'll check the integrity of the pulleys. Thanks Puffy
/ Mower deck belt jumping off again #20
It seems as though it may be aggravated by the fact the deck in lowered. Where did it jump from? Remember as you scratch your head where the belt came off, think of the belt being pushed around the pulley system rather than being drawn around.
2011 Kenworth T800 Truck T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2011 Kenworth T800...
90in. Work Bench (A65640)
90in. Work Bench...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
Kubota SVL 97-2 Skidsteer (A65579)
Kubota SVL 97-2...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
