bulldog front loader
/ bulldog front loader #1
coppertop1
d1650
Hey folks, I have a Mitsubishi tractor with a Bulldog 285 front loader on it. I had the boom cylinders rebuilt not too many hours ago and they did fine..until last week. Now the bucket leaks down fairly quickly. The bucket will pick up and hold the front of the tractor off the ground when I press the bucket down. I thought if just one cylinder was bypassing the good cylinder would still hold the empty bucket. Think maybe its an O ring in the valve body? Any ideas? Thanks
/ bulldog front loader #2
Rarely is it the valve. Typically the valve bore and its spool are fitted to such close tolerances ordinary mechanics can not measure the clearance.
It is this tight tolerance which prevents leakage.
Swap the lift arm hoses for the bucket hoses and see if the problem persists. If so then the problem is in the cylinder(s).
Disconnect and cap the hoses for one bucket cylinder so that you are observing the performance of only one cylinder.
There are more complicated but accurate double acting cylinder tests as I will post below.
Dave M7040
  • Testing double acting cylinders.pdf
Dave M7040 I really appreciate the help.
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A62131)
UNUSED WOLVERINE...
2026 Steel Pines Cargo 8.5x20 Enclosed Trailer, VIN#7FWBE2021T1037982 (A61166)
2026 Steel Pines...
Eagle Weathervane (A61569)
Eagle Weathervane...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
12 Ton Hydraulic Bottle Jack (A61567)
12 Ton Hydraulic...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
