2210 Tractor quit
/ 2210 Tractor quit #1
CFHartman
Keyser WV
John Deer 2210
I was mowing and tractor just shut down, battery checks ok, seat safety switch ok, p t o switch ok, transmission switch ok, we’re do I go from here?
/ 2210 Tractor quit #2
If I was looking for issues I'd probably start with fuel. I'd want to see if I had good flow from the tank. Algae can build up in the tank and stop the flow. If your tank has a vented lid (common) it's possible the vent is clogged slowing or stopping fuel flow. You may also have an issue with the fuel filter or the fuel stop solenoid. After you finish troubleshooting don't forget to bleed the air out of your system before attempting to start it.
/ 2210 Tractor quit
Thank you Roadworthy, but it’s an electrical problem, the fuel gauge don’t move when ignition is turned on, switch checks out OK, battery is OK, ground checks out OK?
/ 2210 Tractor quit #4
Well, if you're SURE it's an electrical problem, start with the fuses. Check them with an ohmmeter as sometimes they can be bad and look good. Clean the battery terminals and the cables that connect to them. Be sure these cables are TIGHT. Follow the ground cable to the frame. Be sure that is clean and tight, too. You may have done all this already but if not it's a good starting point.
/ 2210 Tractor quit
I’m still not out of the woods yet, but I did have a 15 amp fuse blown, I replaced it and checked the rest, Mow the panel will light up and the gas gage works but still no cranking, going to play with it tomorrow, thanks for the advice,
/ 2210 Tractor quit #6
Just a thought... is the HST lever actually in Neutral (to start)? The selector may have 'jounced' or been bumped out of High or Low.
I know that on my 4105, there are 'spots' where it's 'just about but not quite' in position.
/ 2210 Tractor quit
I would definitely like to thank all who made suggestions here, it was a fuse, after finding it I had not reconnect the PTO switch, I had to walk away for a couple days, I went back at it this morning and found the disconnect switch, plugged it back together and everything is OK thanks for the help,
/ 2210 Tractor quit #8
:thumbsup:
And thanks for letting us know it is fixed.. we all have been there.. :)
2012 KENWORTH T800 KILL TRUCK (A60736)
2012 KENWORTH T800...
2017 CATERPILLAR 262D SKID STEER (A62129)
2017 CATERPILLAR...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2020 DRAGON ESP...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
Zero Turn Mower (A59231)
Zero Turn Mower...
