Rotary Cutter Best Rotary Cutter?
/ Best Rotary Cutter? #21
I’m surprised Rhino hasn’t been mentioned. They are in the same class as Bush Hog. Don’t overlook them.
All of these manufacturers have different lines/levels of cutters. Sort of like the old “Good/Better/Best” in the old Sears catalog. Make sure you’re comparing apples to apples.
Rhino mowers mentioned in post #11
/ Best Rotary Cutter? #23
And great information in that post!
I hope the OP reads it someday. :thumbsup:
Thanks. I try to inform others based on 35 years in both construction and farming. Not sitting behind a desk with an engineer degree :laughing: I don’t always make the best decisions, but when I know and believe in something that works well, I try to show newcomers what works!
/ Best Rotary Cutter? #25
Each brand makes at least 2 and most make 3 grades of their cutters. Buy one and use it how it was intended and I think you値l be OK.
One brand that was not mentioned is Alamo! I know a fellow who has one and says it痴 the heaviest and best cutter he痴 ever owned. Look them up and you値l find out they own Bush Hog brands!
/ Best Rotary Cutter? #26
/ Best Rotary Cutter? #27
John Deere, Land Pride, Bush Hog. Any one of those three. Possible Woods if the deal was right.
I always thought Woods was a JD/ Frontier just painted greedy green ! BTW I don't think anyone's mentioned Schulte ?
/ Best Rotary Cutter? #29
Schulte is a really HD cutter. Only problem - I think their FX107 @ 84" is the smallest they make. I like Brown but service and parts are still in Ozark, AL. My top pick would be Rhino Twister 30 series. There is a local dealer for sales, parts & service.
/ Best Rotary Cutter? #30
How about an old Rhino Tw-72? I see one for sale w 100 hrs on it, for 1100. Should I get it?
/ Best Rotary Cutter? #32
Higher-end cutters that are able to cut larger diameter stuff begs the question: Do you really want to be around all the racket that cutting huge stuff makes? My BH26, which was amply "tested" by the previous and original owner (commercially- mowed LOTS of rocks with it!), has managed to take all the abuse that I care to toss its way: I tend to find the limits on everything- with the RC I can only go so far as my nerves will start to fray before the RC frays!). In my experience it's tail wheels that are the weakest parts: when you're backing into brush with unknown stuff in there you can really put a lot of stress on tail wheels. I'd also want a cutter that is going to break before it breaks my tractor! (shear pins and slip clutches aside)
Decks rusting and such is likely a bigger issue for many (rust isn't real agressive here in the PNW), in which case thicker decks are a plus.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
ACETYLENE AND OXYGEN BOTTLE (A68842)
ACETYLENE AND...
2016 John Deere 1200H Bunker Rake (A66734)
2016 John Deere...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
