Front loader bucket has some holes in it and might need welding?
   / Front loader bucket has some holes in it and might need welding? #1
draku007
Member
NJ
Kubota L3300
My front loader bucket is getting pretty thin at the end of the bottom section to the point where I'm starting to see some holes there (see attached picture - red marks). Any suggestions on how to best fix it and extend the life of the bucket (I really don't want to buy a new one anytime soon).
   / Front loader bucket has some holes in it and might need welding? #2
What kind of welder do you have?
   / Front loader bucket has some holes in it and might need welding? #3
I would cut out the worn out corner (red) and weld in a flush patch and weld a full width wear strip on the underside of the bucket to preserve the buckets bottom corner width. (Yellow lines)
A 3 inch strip x 3/16or 1/4 inch thick would do.
   / Front loader bucket has some holes in it and might need welding? #4
I had the same problem as you. And Big Barn has a good solution, very similar to mine. Although I didn't cut out a section that was worn, but rather ground it down to good, bear metal, and then welded the "wear plate" to the bottom of the bucket, and finally welded shut the slot I ground down in the original bucket material. This way, it keeps you from burning a larger hole in the bucket if you get too aggressive with the weld. The newly installed wear plate acts like a backer-board for the final weld. (I'm not a professional welder and I need all the help I can get).
The bucket steel is very thin, probably only 1/8". I put an 8" deep wear plate on mine, because I back drag a ¼ mile gravel drive every 4-6 weeks to keep it smooth. Wear plate has held up nicely.
   / Front loader bucket has some holes in it and might need welding? #5
I have found 7014 a good easy to start and run rod if you have a DC stick welder. I like to use it to fill holes. It runs like butter.
   / Front loader bucket has some holes in it and might need welding? #6
I wish I had your skills as you’ve shown some of your work. I’m an expert welder until I start a bead, then not so much.
But I do know enough to see a hole in the bucket.
   / Front loader bucket has some holes in it and might need welding? #7
Thanks. I will keep this repair in my memory bank. I’m still learning.
   / Front loader bucket has some holes in it and might need welding? #9
Well as they say, the first step to the solution is to acknowledge the problem.. :) So you are well on your way.
   / Front loader bucket has some holes in it and might need welding? #10
Like us all.
Rgr, that. Bigtime. I have repaired some holes in some buckets, but that don't make me no expert. I am not sure I would even make a pimple on a good welders....... :)
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
