CoyPatton
- Joined
- Aug 10, 2015
- Messages
- 1,651
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
Ran across one of these locally for cheap. Thinking about pulling the trigger on it
I regularly mow about 2 acres and bush hog another 2. Lots of hills on the bush hogging. Would a yanmar 2000 be better instead of a zero turn for all the mowing? I could see this tractor paired with a 4 ft finish mower....
Also, what would be reasonable for pricing on this model in todays market? Its definitely the 2wd model, unsure of hours but I hear its mostly irrelevant with these
If your ground is mostly level on the mowing, a ZTR can not be outdone for mowing in my opinion.
However, a ZTR is not a rough cut type mower. They can also have issues with steep hills. On any hill it is always best to go up and down the slope not across in any way. Also with a tractor you may need front weight to maintain steering capability.
As for hours, these yanmars will run for 1000’s of hours if not abused. So while hours are an indication of use, overall general condition is at least as much a concern as hours.
If too many things stack up, run away.
Issues:
water in oil
Oil in water
Water in hydraulic fluid
Any fluids being mire than slightly low
Lots of indications of leaks
Grinding gears
Non working items
3PH
Diff lock
Either brake
Not intended to be all inclusive, but to start a thought process when looking at the tractor
