Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #1
tedward4
Rochester, MN
'84 Ford 1710, '87 Ford LGT 14D
Hi Everyone,
A while back I posted some pics of the rear remote valve I made for my 1710. See the last pic below, and here's a link to the original post:
https://www.tractorbynet.com/forums/new-holland-owning-operating/344051-ford-1710-rear-remote-valve.html
I've had several people see that post and ask for help with their rear hydraulics. Most recently, a member requested help with plumbing a backhoe to the tractor hydraulics. He didn't need the valve mounted to the tractor, but just the bower beyond capability. He also didn't like plumbing into the diverter valve in front of the right footrest and running hoses to the back of the tractor. After unsuccessful searches for a HV4950 or SML25854 adapter plate, I ended up machining an adapter. I originally thought that this adapter would only fit the 1710, but it looks like it will fit the 1100-1900 (with slight modification) and 1110-1910 tractors with position control 3pt. Hopefully after all the messing around with the hydraulics I can be helpful to others looking to add rear hydraulics.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #2
Similar to the 1700 adapter.
Yep, exactly what I was going for except I put a second set of ports on the top so you can run hoses to the back of the tractor more easily. From my looking, those 1700 adapter plates you showed are really hard to find from either NH or aftermarket.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #4
Oh ya Messick has them also.Screenshot_20200423-123219_Chrome.jpegScreenshot_20200423-123258_Chrome.jpeg
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #6
I had to call them and they located 1 through a vendor.
What would a kit like this cost?
$150 shipped. It includes all the fittings, orings, and hardware to mount. I made up 3 of them so have 2 left on the shelf. Send me a PM if you're interested.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #8
Are you mounting the relief valve to the block adapter?
I've only seen the 1710 tractors with relief valve up by the right footrest. 1700 tractors seem to have it mounted on the quadrant cover. I have a version of the adapter plate for the 1700 as well.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #10
Ya because the adapter plate is between the relief valve and control valve plate on my 1700.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #11
Hi Everyone,
View attachment 651489View attachment 651488View attachment 651487View attachment 651486View attachment 651485View attachment 651484
I assume this kit would NOT fit my 1920?
Nope, won't fit the 20 series tractors. Search for HV4945, I see some on eBay for ~$100 that fit the 1920. Not sure if the 1920 came with different plates like the 1710 did. The 1710 had position control of draft control and the plates were different.
Found a pic of the 1710 relief valve and diverter block. I don't think the 1700 is the same as 1710.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #15
Greetings from a new member in CT.
I've added a good number of add on's to my 1710. I/m looking to add a hydraulic front grapple to do firewood.
I was planning to tap the hydraulics attached to the three point lift lever notch on the right side of the seat.
I am planning to tee the new hydraulics to the front and the back of the tractor.
May I ask your thoughts on using your power beyond block vs taping into the three point notch extra ports?
Thanks
Everett Condit
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #16
Hi Everyone,
Ford 1710 Rear Remote Valve
Greetings ...
I'm a new member in Ct. I'm wondering if you have any of the power beyond Aluminum adapter plates for a Ford 1710.
I think my post and pictures are at the end of your post.
I'm looking to add more hydraulics for a grapple for cutting fire wood.
My email is ecec240@gmail.com
Thanks
Everett
( A Tech. Ed. teacher from Ct)
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #17
7/1/21
Greetings all...
Ted, thank you for posting the Aluminum connector block pictures.
Just today I got back to the project and pulled the three bolts under the seat and the triangular plate from under the seat. A quick start up had the hydro fluid pumping out of the lower front hole your "O" mark.
A quick give back...
While doing the bucket log lift project, and the log splitter log lift project, I found a company that has pistons, pumps, valves, every size and type of connector ever made... and more at great prices. The name says "surplus", but everything is new unless marked. They also offer a free catalog. Have a look at:
www.surpluscenter.com
Thanks again
Everett
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #18
Do you have any left for sale? I would like to run a 3 point log splitter on my 83 1710.
I'll be machining a batch of 10 so will have more available in a few weeks.
   / Ford 1710 (and others) Hydraulic Power Beyond Adapter Plate #20
Hi Tedward. I would be interested in one. I am going to send you a PM for more info. Thanks!
2016 KENWORTH T680 TANDEM AXLE DAY CAB (A59905)
2016 KENWORTH T680...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2021 KENWORTH T680...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 CATERPILLAR 926M WHEEL LOADER (A60429)
2019 CATERPILLAR...
