JD 4200 won't go forward or backwards and PTO won't function
   / JD 4200 won't go forward or backwards and PTO won't function #11
Forward and Reverse do not work. PTO cut out at the exact same time. The rest of the hydraulics work perfectly, so I ruled out the pump.
The pumps you ruled out are the steering pump and implement pump, which supplies rockshaft (3pt hitch) and SCVs. They are not part of the hydro drive.
Going through the repair manual and the only component I'm seeing that could affect the forward/reverse and PTO would be the hydrostatic motor. I'm trying to figure out how to test this without splitting the tractor; has someone on here had this go out on a similar model?
There is an engine driven hydrostatic pump that supplies the hydrostatic motor, both are internal.
Does your Tech Manual tell where there are any test ports to check for pressure? Is it a JD Tech Manual?
   / JD 4200 won't go forward or backwards and PTO won't function #12
My understanding is there is a charge pump thats on the side of the engine that then goes to the hydro pump. I believe this also runs the power steering but it almost sound like the charge is lacking pressure or there is a valve in relief.
The F/R relief valves and I think the charge pump relief valve are all right under the floorboard right next to the where the hydro filter is. This is also the place where you run your pressure tests.
If all mechanical linkage has checked out. I would say the next step would be doing some pressure test.
Will your FEL or 3ph work? If not, your driveshaft Ujoint likely broke. Happened on my JD 4010. Nothing would work. Steering does, but hard.
Ralph
Yes, all of the hydraulics work just like before.
Yes, I believe I found the procedure while looking through the manual yesterday afternoon; but I haven't had a chance to test it yet. The tractor failed on top of a sketchy pond dam, so I've got to get it pulled out of there and up to my shop to take a look. It never happens in a convenient manner, right?
I think you're right on this, so I will get a high pressure gauge to perform the tests. I believe I saw the pressure to read was around 6,000 PSI in my tech manual. Thanks for the help.
   / JD 4200 won't go forward or backwards and PTO won't function #16
If the tractor does not have a neutral position? Find out what has to be done BEFORE pulling it. The only hydrostatic drive I have is my Lawn tractor and it has lever to release something (a valve?) so you can roll it with engine not running.
   / JD 4200 won't go forward or backwards and PTO won't function #17
There is a neutral position, as well as a low, medium, and fast "gear" selection.
Be sure that it is in one of these positions and not caught in between.. which can happen but don't know if that would cause the results the OP has going on here.
It has a neutral position on the gear selector, but I will check in the repair manual for towing considerations before doing anything. Thank you for the advice, though.
I was really hopeful this was the issue, but I cycled through A, B and C gears and no movement.
   / JD 4200 won't go forward or backwards and PTO won't function #20
Thanks, I was not sure if it has a neutral position.
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
