Lift Arm Spacer(s)
/ Lift Arm Spacer(s) #1
hthomure
Member
Central Missouri
Kubota B2910
Hello all. I've searched for this topic, and only found one thread on it, and it never really got resolved, so I'm going to resurrect it.
I was messing with my lift arms the other day and happened to notice that one arm has a spacer where it attaches to the PTO, but the other arm doesn't. I just assumed both arms need one, so I started the search process to find one to order. While searching is when I discovered the discussion as to whether or not both sides needed a spacer. I know my mowers pull to the side all the time, and I was thinking that might be the cause. But now since I discovered this discussion I'm not so sure. Attached is a photo of what I have currently. Yes my tractor is filthy.
Thanks for any help.
/ Lift Arm Spacer(s) #4
Yup, supposed to be on both sides.
/ Lift Arm Spacer(s) #5
You do need another on the left side.
Have your dealer order one for you.
SDT
/ Lift Arm Spacer(s) #6
Make one from a piece of pipe.
/ Lift Arm Spacer(s) #8
Have to remove lift arms to install backhoe. Lost one spacer. Cut about 1/4” off a standard cat 1 to cat 2 sleeve from any tractor supply store.
2008 Ford F-350 King Ranch 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-350...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
2012 CAT 336E W/SHEAR (A67714)
2012 CAT 336E...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2025 Swict 78in Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
