YM276D Top Link
/ YM276D Top Link #1
richriddle
Gold Member
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
The YM276D top link upper thraded portion bent. Is there a way to get this part only or does one simply replace the entire top link? If the thread size was available, one of the same thread size can be ordered as well. The current top link has a welded bar on it that makes it easy to adjust.
/ YM276D Top Link #4
Just about ANY tractor store or coop store sells generic top-links of various sizes for tractors. Mine came from my John Deere 850 (YM2500 painted green) :D
Those welded bar studs either bend or break due to heavy use with a pry bar. Oh, did I say that. LOL Been there and did that a few times. Now, I just use anti-seize on the treads. Makes getting the top-link off so much easier.
/ YM276D Top Link #5
Too have bent the top link, carefully examine your lower arms and the pin mounts on your tractor. Generally, the lower arms will take more abuse than the top link when hitting something going backwards. I assume you were either backing up and ran into something non-movable or was grading backwards and hit something very solid.
/ YM276D Top Link #6
Coy, you are sooooo right! I just walked out to the garage, picked up the top-link I only use for snow removal because it's bent and the threads are jammed. It works great for plowing and nothing else. I don't want to break the good one either from the JD850.
Rich, you may want to SAVE the bent top link for those jobs like 3PT blade snow removal in reverse or similar activity. Then with a GOOD top-link anti-seize the threads and treat it like gold. :thumbsup:
/ YM276D Top Link #7
Hey that's what the hole at the end of a Crescent Wrench handle is for!
Put the force near the weld, not several inches out.
And yes, lube it. I like non-greasy silicon lube so dirt won't stick.
/ YM276D Top Link
The bend did NOT occur with RR in the seat. A former worker literally broke every tractor at the farm, and most likely he intentionally broke things. He broke machines and tools as well. The Stihl dealer once said, "Stihl doesn't warranty items for abuse or misuse" when he looked at a broken tool. The cause of the top link is unknown, but the tractors have never broken since the former worker left (with the exception of the brake on the YM276D rusting together over the winter). Well left is one way to put it.
/ YM276D Top Link #9
Now may be a good time to consider a hydraulic top link. If your tractor has rear SCV. I got mine from Brian at Fit Rite. A wonderful addition to any land engagement implement. They are custom made for your tractor and are several times stronger than the OEM top link.
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2009 Chevrolet 1500 Savana Van (A63116)
2009 Chevrolet...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
ALLIS-CHALMERS GLEANER F2 COMBINE (A63290)
ALLIS-CHALMERS...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
4ft Mini Skid Quick Attach Rotary Cutter (A63118)
4ft Mini Skid...
