knocking noise
/ knocking noise #1
nosaj2
Member
none yet
I know this is a long shot. Can anyone make an educated guess what this knocking sound is? Brand new Branson 2515 less than 10 hrs.
/ knocking noise #2
I definitely hear it.
10 hr.s eh? Have you gone over your rig and tightened every nut/bolt that you can see/find?
Greased every grease nipple (zerk)?
If it moves, but doesn't have a grease nipple, given it a shot of lubricant?
Confirmed the torque on the wheel lugs?
Ensured that the fluid levels (oil/hydraulic/coolant) are topped up?
/ knocking noise #3
My NH Boomer made a similar noise and it was the muffler starting to come loose at the engine manifold. Torqued and never came loose again.
/ knocking noise #4
Interesting that you shared this. I have the same exact noise, but mine goes away if I press the clutch. With yours being an hydro, you don't have a clutch, so whatever causes the noise shouldn't be related to a clutch.
This was actually discussed in this thread: https://www.tractorbynet.com/forums/century-branson/428210-branson-throw-out-bearing-concerns.html
I have a video of mine, doing the noise. It's more noticeable at higher RPMs. At first, we thought it was clutch related because K5's Branson is also Shuttle shift, but after checking your video, I guess it's not.
Anyway, I'm a bit over 230 hours, most of hard use, and so far I haven't had any problems with either the clutch or the engine.
/ knocking noise #5
Mine is definitely the throw out bearing. It only makes the noise when I push the clutch in to stop. I have no idea what is making that sound on your tractor. Interesting.
/ knocking noise #6
My 2400H has clutch that is used to engage & operate the PTO. Does the 2515 have this also?
Clutch also removes drive power to the HST
/ knocking noise #7
Sounds like a diesel to me. If you don't like it, get a tractor with an Isuzu diesel or one with a diesel similar to what's in a VW TDI. Have an Isuzu diesel driving our Central Maine generator. It sounds like a gasoline engine. So did the VW TDI.
Ralph
/ knocking noise #8
Ralph
It's not the engine sound. It's the rattling sound over the engine noise.
Here is another example at around 1 min mark:
/ knocking noise #9
It sounds more noticable at higher RPM's. Have you looked for anything loose in the engine compartment? Belt, fan hitting shroud etc?
/ knocking noise #10
determine exactly how to make the noise happen and run it in to the dealer. nice its warranteed
/ knocking noise
no. It's independent PTO.
/ knocking noise
They are coming to get it today. I prefer to have an idea of what is wrong with something before someone "repairs" it. But Diesels are new to me for the most part. Thanks for everyone's input. I'll try to post what they find and if it resolves the issue. I personally wonder if it is injector related. But like I said I'm not a diesel vet.
/ knocking noise #13
Sounds more like drive train noise - your test performed in 4wd ?- I dealing with noisy drivetrain in 4wd something out of alignment 37 hours into noise, New tractor. Dealer has call into factory for explanation have six year warranty. If it breaks they will cover it 100 % since I reported an issue. Nobody knows what it is.
/ knocking noise #14
My guess is the front drive joints. Have someone drive the tractor and you walk beside the tires. Jack the front end up and wiggle and spin the tires. Make sure they sound and spin the same. Check all rotating front drive parts for something loose.
hugs, Brandi
/ knocking noise #15
My bet is something in the exhaust. I would start by checking the muffler.
/ knocking noise #16
No U-joints on these tractors. Straight shaft with splined couplers for the 4WD.
For the OP, since his tractor is an HST and doesn't have a clutch, I don't really know what the sound is.
On mine, is definitely something in the clutch. Probably just the springs on the clutch disc rattling around. Once it gets under load, it goes away. I'll take a inspection plate under the tractor and check the clutch stuff again.
/ knocking noise #17
I'm going with exhaust on this one too. The second vid really make it sound like a heat shield is loose. Does it make the rattling noise when the tractor is at full throttle but not moving??
/ knocking noise #18
No heat shields on this one though. Well, just one under the exhaust manifold but it's tight. It does make the noise while sitting but, the again, if I press the clutch, it goes away.
IMG_20181114_110102.jpg IMG_20181114_110136.jpg IMG_20181114_110148.jpg IMG_20181114_110226.jpg
/ knocking noise #19
PTSG your situation since it is a clutched tractor almost sounds like it could be the throw out bearing. I think your in the right direction looking toward driveline. How many hours are on the tractor and does the tractor have a grease fitting somewhere down by the foot pedal that goes to the bearing.
/ knocking noise #20
In PTSG’s case it would not be the throw out bearing. When he pushes down on the clutch it goes away. If it was the throw out bearing that is when it would make noise.
In my case it was the clutch plate rattling when clutch is fully depressed. If I let off just a bit it goes away.
2014 Ford Focus Car, VIN # 1FADP3F21EL104239 (A61165)
2014 Ford Focus...
BUNDLE OF APRROX (45) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
2006 Ford F-550 Flatbed Dump Truck, VIN # 1FDAF57PX6EB82087 (A61165)
2006 Ford F-550...
UNUSED INDUSTRIAS AMERICA 170-7' SCRAPE BLADE (A62130)
UNUSED INDUSTRIAS...
Hydraulic Asphalt Scraper Skid Steer Attachment (A61567)
Hydraulic Asphalt...
2026 Steel Pines Cargo 7x18 Enclosed Trailer, VIN#7FWBE1832T1036525 (A61166)
2026 Steel Pines...
