SLTX1054VT won't move
/ SLTX1054VT won't move #1
Oceantoad
Cub Cadet SLTX1054VT
I have a SLTX1054VT with the hydrostatic drive. It started slowing down going up small inclines the last few times I used it. Now it won't even power through a turn. I checked the mower deck belt, fine. I checked the drive belt, fine. I have watched a few youtube videos on putting fluid into the hydrostatic transmission on other tractors, but I don't think this trans has any access or fill ports. I have read that they are sealed at the factory. Is there a way to fix this issue? Suggestions? Thank you in advance.
/ SLTX1054VT won't move #2
I'd double check your hydro "drive" belt. Had one that did pretty much the same thing and I " thought " the belt was good. The belt runs the pump all the time regardless if you're moving or not. So it could slipping and you really don't know it. You have to remove the deck for replacement. Not real fun.
And yes no way of checking the oil .
Thanks 4get gto. I'll look at it again. Hope it's something that simple.
/ SLTX1054VT won't move #5
HARDEE 8' ROTARY MOWER (A63290)
HARDEE 8' ROTARY...
3015 (A56857)
3015 (A56857)
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2002 SHOP 20' FLATBED GOOSENECK (A63569)
2002 SHOP 20'...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
