Tiller Chain drive lube
/ Chain drive lube #1
Bing187
Rehoboth, Massachusetts
Kubota B3300SU
Hi Folks,
Anyone have a lube that they swear by for chain drive on their tiller?
I have a Land Pride RGA 1258 tiller. Need to do a service (overdue) and the manual specs 80-90w for the gear box, simple enough and readily available, but the chain drive is needing Shell Gadus V220-00 "flowable grease", or Land Pride #821-045C...?. I've checked with my local auto parts place (Not a NAPA or Autozone...local guy that can usually get me ANYTHING) and Tractor supply..... They've never heard of it and the interweb doesn't offer any equals to them... Do I just have to suck it up and order online or go to my nearest Land Pride dealer (Hour away)?
Also curious if anyone has a go to for replacement teeth and drag shoes for Land Pride tillers... I figured on buying online, but want to keep it simple, so if anyone has a reliable supplier, I'd rather go through someone I can trust.
Thanks!
Mike
/ Chain drive lube #2
Good question. My new RTA1258 tiller calls for Shell Gadus oil (or equivalent) on the sticker on the tiller.
The manual calls for straight SAE 90 wt.
90wt gear lube is hard to find at tractor stores etc. my Mercury Outboard Dealer has it.
I would expect 80/90 wt would suffice.
/ Chain drive lube #3
Go to your local motorcycle store. They will have excellent types of chain lube. You are looking for a lube that will penetrate and the dry on the chain -like wax. Good brands of chain lube will do this.
/ Chain drive lube #4
oosik is right, motorcycle chain lube is good. Amsoil has a good spray that dries also.
/ Chain drive lube #5
Don't tillers have enclosed chain cases? Spray lube is for exposed chains.
/ Chain drive lube #6
Great flowable grease.. John Deere Corn Head grease. inexpensive and easy to get.
been a popular grease for brush cutter gear boxes.
/ Chain drive lube #8
This is an enclosed oil bath type chain. Your advise is good for open, exposed chain drives. 00 grease is not terribly hard to find. 00 grease is also sold as corn head grease. You may also find 0 grease at a NH or CaseIH dealer in a quart bottle labeled E P Grease. That will be close enough. The only reason Landpride does not specify 80W-90 or 85W-140 gear lube is the lower shaft bearings & seals will not keep the lube on the right side of the case.
/ Chain drive lube
Thanks all.
I don't think a spray on or typical "chain lube" would fit the bill.... it calls for a 32oz bottle, so I assume it keeps the chain submerged in it as it spins... I'll try to find the John Deere Corn head grease, or the New Holland dealer for the 00 E P grease. I was hoping that somebody would say "Hey dummie! that's just xxxx lube, under a different name" lol. If I can't find one of those, I'll ante up and get the Shell product and buy enough to do it a couple times.
Any thoughts on a source for teeth and skid shoes?
Thanks!
Mike
/ Chain drive lube #10
Perhaps I looked at the wrong manual, but to me it appears that both the gearbox and gear case take 80-90w gear oil. No chain, enclosed or not.
/ Chain drive lube
Must have been the wrong manual. It definitely has a chain drive, and the manual specifically specs two different lubes.
/ Chain drive lube #14
I've been running 80-90 in my tillers for many many years, I've never had even one problem...
I've got aprox 2,000 acres on one of my tillers, that should be a good enough test!!
SR
/ Chain drive lube #15
SR
As stated, 00 is specified in the Landpride tillers because 80W-90 will not consistently stay in the chain case over the long haul.
YMMV and apparently yours does.
/ Chain drive lube #18
Gosh, on exposed chain anything 'greasy' is better than nothing.
Motorcycle chain oil being best as it is designed to reject dirt and not fling but all being said any lube will save the chain.
What U don't want is rust that will bind the links and cause the gear teeth to wear out prematurely.
/ Chain drive lube #19
There's two kinds of motorcycle chain lube- dirt and street. Street chain lube is sticky so it won't get flung off at high speed. Dirt chain lube is less sticky since chain speeds are lower and sticky lube will attract dirt which wears the chain and sprockets.
/ Chain drive lube #20
That is pretty obvious. The 12 series are a low rent tiller with a name brand decal.
I've never seen one up close, so I had no idea... I guess I assumed all of them were sealed up good enough to use 80-90...
SR
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
Suzuki King Quad 700 (A62613)
Suzuki King Quad...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
Mini Universal Forks (A65640)
Mini Universal...
