   / Your last generator Maintenance Run #4,051
Well I had the opportunity TWICE over the last 48 hours to perform 'maintenance' runs on my genny.
First time we were blacked out for 3.5 hrs and a mere 6 hrs later hit again with an 8 hour blackout.
First incident was from a branch that blew the transformer fuse but took a fair bit of time to locate where.
2 nd incident was a blown transformer that knocked out some 150 clients while the earlier incident only affected 30 or so homes.
Problem here is that many power lines run thru the forest as power was installed before we had a road and later when road was made it followed the terrain vs the property lines.
That early hydro line was all laid using tracked 'muskegs' and boats.
Maintenance consists of cutting trees and that for a mere 25 ft 'right of way' and trees have a habit of growing much taller than hydro lines.
As a result being in a high elevation winds topple trees across the hydro lines.
Then to further vex us the telephone lines also get damaged.
Now also add that cellular service is very spotty due to the mountains.
So U call to report an outage and the recording says to go online (duh) and about 15 mins of useless info B4 you can actually make a report.
Like confirm no power??, your addy, do neighbors have light (can't see their house), check fuses, etc etc. press 1 to confirm addy, 2 to confirm something else etc.
LOL, all that frustration while holding a flashlight in order to read the phone keypad.
Heck if we had a medical emergency we'd need to wait until power was restored to call for an ambulance.
Now I have a water table problem and need to run my sump pump every 2 hours or so so I had to wake up 3 time during the night to do so and run the genset for 10 mins each time. That was no fun! OK, I have a digger out back and will cure the water table over the next few days.
   / Your last generator Maintenance Run #4,052
All these automated systems are quickly becoming worse as they get more complex. As are the Government/Municipal Websites. Up until a week or so ago, I could Google my Garbage pickup schedule, and click on a PDF. DONE. Now I have to agree to cookies (which I don't) and am expected to engage in some interactive "experience"! NOT interested, so I am back to calling the municipal office to talk to the garbage lady and she mailed me a schedule. That's supposed to be Progress!
If you have a phone problem, and know EXACTLY where the problem is, there is no way in helll you can convey that information. In fact, now, they only have three choices for a trouble report. Like, DEAD, STATIC and some other one.
   / Your last generator Maintenance Run #4,053
PILOON: Sorry to hear that level of crazy. Our electric co-op has web-based, cell phone app-based, and text based ability to report outages. It's all computerized. Folks make their reports, every 5 minutes the computer tabulates an affected (potentially growing) area, which triggers the personnel response. The co-op can immediately tell if it is likely a simple local problem or a more major equipment failure just based on the customer reporting. And you don't need the ability to call. Text messaging can work (and auto-retry) with worse reception than necessary to complete a phone call.
Water.... the first most critical thing we humans need, but also they key reason I want at least one healthy gen ready to go at all times.... Water table (seasonal issue) here can't readily be cured by digging - you are fortunate if it can be quickly addressed with a backhoe.
Trying times for you lately Piloon, but at least you have the skills and equipment to deal with it. Doesn't make getting up multiple times overnight with an alarm better...... price paid for a good outcome though......
Blindly or indifferently implemented tech (done mostly to replace humans) is often pretty infuriating. In my day job, if I need to call CAT or for Pete parts, their phone systems will seamlessly bounce to another (competent) physical site if their local one jams up too badly. Not a bad use of tech, IMO, but the key is it is used to get you to another competent PERSON in a timely fashion.
Too often, you just end up punted into a Can't Get There From Here morass if tech is just used to deflect direct contact......
Rgds, D.
   / Your last generator Maintenance Run #4,055
Can't believe it. Friend and his Diesel FORD, STILL stuck in WAWA! Thank You technology!
Good diesel techs are in short supply. It can be even tougher for a light-vehicle dealership to hang onto them. When Things Go Wrong..... often easier to find a competent gasoline tech.
I was pretty much there a while ago, but what I've seen these last couple of years..... I have zero interest in driving a modern diesel. Correction - driving them is fun, it's owning one I have no interest in......
I don't look forward to when generators are commonly using this "New Improved" diesel technology......
Rgds, D.
   / Your last generator Maintenance Run #4,057
I hope I have my supply of non electronic sets taken care of for the remainder of my time here.
Wishing everyone well, who is affected by Isaias.
Being able to safely ride things out at home through any emergency is attractive, but esp. so these days.....
Rgds, D.
   / Your last generator Maintenance Run #4,060
having sold my farm and all my generators...and now checked out of assisted living and staying in my motorhome, I think not much sleep Tuesday night.
Taking rv out early tomorrow to fill internal propane tank, likely to lose power for awhile. Thankful there is a 3kw propane gen built in.
Tried to get it filled on Friday and car broken down right in front of
propane fill station and no one could get near hose, bad luck for all.
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
40ft High Cube Shipping Container (A54865)
40ft High Cube...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2012 JOHN DEERE  624K WHEEL LOADER (A55745)
2012 JOHN DEERE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
