Anyone level their lawn with sand?
/ Anyone level their lawn with sand? #1
bdog
Elite Member
Texas
John Deere 6130M
We laid sod back in April. The ground was leveled well before we laid it and we rolled the sod twice. It wasn稚 really bad but mowing at 3/4 with a reel mower you could sure see the high and low spots.
Decided to level it with sand. Entire project took about six hours and 5 yards of sand with me doing the work by myself. Without the BX to shuttle the sand around it would have been a lot harder.
This side I just spread the sand on today. This picture is just it raked in and not smoothed with the leveling tool.
I did the exact same thing to the other half of the yard two days ago and it has already grown in this much.
I can稚 wait until I get to mow again and see what a difference it made.
/ Anyone level their lawn with sand? #2
It's always worked for greens keepers :thumbsup:
/ Anyone level their lawn with sand? #4
yes. you don't say what type turf you're running, but my Zoysia likes masonry sand for fill-ins. Doesn't introduce weeds like dirt could/would.
It is celebration bermuda.
/ Anyone level their lawn with sand? #6
Looks good!
How did you spread and rake it?
I dumped small piles across the yard with the BX and then used these.
I actually spread it around with the rake. The picture above is just with it being raked. After it is spread it needs to sit for a couple hours until it dries then I worked it in with the leveling tool. The leveling tool is useless when the sand is damp. It just clumps together.
/ Anyone level their lawn with sand? #8
You can never be too carful about what's brought in. Sand in Texas often has sandburs or goat heads growing in it. I once bought concrete truck "washout" for road base and wound up with sandburs.
I had that concern but nothing some preemergent won’t take care of. That being said mowing at 1/2-3/4” every three days there are not many other plants that can survive.
/ Anyone level their lawn with sand? #10
Learn something every day on TBN...
The sod in back is a little rough from gophers/moles and trenching...
/ Anyone level their lawn with sand? #12
Our son in the Denver area says they don't recommend mixing sand with the heavy clay soil as it tends to set up like concrete.
I have thought about trying it here in North Central Kansas on our fescue lawn, however.
The only thing to be careful of is not going too thick at once or you can smother the grass. What I read was 1 yard of sand per 1,000 sq foot of lawn. I have a unusual desire to have my yard perfectly smooth so I plan on doing this once a summer for maybe the next couple years. If your yard is really unlevel I would suggest not trying to fix it all at once. We had a trench that settled some in the yard that I leveled with sand prior to doing this and it grew back quickly where the sand wasn’t thick but where I put it thicker it didn’t grown back through and had to spread into it again.
/ Anyone level their lawn with sand? #14
I have done top soil in layers over several years but sand sounds quick and easy...
/ Anyone level their lawn with sand? #15
One of our master gardeners more or less did it with compost. She pretty much buried her grass in it and then used a rake to bring some of the greenery to the surface. Be better for the grass health than plain sand.
Ralph
/ Anyone level their lawn with sand? #16
We couldn't get away with sand in the Midwest. I shovel loose topsoil in or near the problem areas in August and then run my 8" landscape rake over it. Then seed with a seeder/packer and it works real well.
/ Anyone level their lawn with sand? #17
No sense me leveling my lawn, the moles will just unlevel it.
/ Anyone level their lawn with sand? #18
Sand is great... as long as it isn't salty. Throw peat moss on as well to help hold the moisture. Sand doesn't.
/ Anyone level their lawn with sand? #19
This is why my turf is a mine field... for years the gophers and moles had free reign...
I gone through pails is Answer to make a dent.
Knowing what I know now would make me consider installing stainless mesh.
/ Anyone level their lawn with sand? #20
They say one man's poison might be another man's meat. Once you've dealt with clay soil hard as cement when dry then sticky as bubble gum when wet,soil that moles are able to burrow through is a blessing.
I can send you a pregnant feral guilt that will wipe out all signs of mole and gopher damage and give you an endless supply of fresh pork. Your little D-3 would be perfect for tidying up behind your pigs.
UNUSED LANDHERO CHAINS & BINDERS (A62131)
UNUSED LANDHERO...
Tractor with sweeper (A61567)
Tractor with...
2024 Case TV620B High Flow Forestry Compact Track Loader Skid Steer (A61567)
2024 Case TV620B...
2007 FORD EXPEDITION XLT (A62130)
2007 FORD...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
