locknlube cupler for a grease gun
   / locknlube cupler for a grease gun #311
I forgot to add, I still have to swap out for my old (regular) fitting to get to a couple of fittings ... which the LNL doesn't seem to fit onto quite right.
Seems many have this issue. I put my original coupler back on for this reason. I even contacted LNL and let them know. One person reporting it didn't matter, now if everyone that had the same issue would contact them, I bet they would make a smaller diameter one ASAP!
I'm considering returning the LNL coupler as it didn't work for 60% of the application I bought it for.
   / locknlube cupler for a grease gun #312
I was never that happy with my standard LnL. It finally started leaking so bad I had to install the extra jaws and o-ring supplied with it. Was just about to throw it in the trash since I couldn't get it apart. I finally clamped it in a vise and used vise grips on the barrel to get it apart. It works better than it did to start with the new parts in it. Next time it goes in the trash though. I might try one of the $15 generic versions. Saw one of those with 55 5 star ratings.
   / locknlube cupler for a grease gun #314
I just used my XL today, and i am not sold, it worked on 80 percent of the zerks, but some it wouldnt clamp on, and on 2 it was TOO LONG, I wonder if Amazon will let me return it even though I used it and get just the regular sized one?
   / locknlube cupler for a grease gun #315
It is just an old guys: "I have been using my old lever style grease gun forever, and it works just fine for me" type thing.
I bought a DeWalt 20V grease gun last Fall.
Just decided to try it today (July 18).....WOW....it is GREAT!
My lever style grease guns will NEVER be used again!
Yep. That's what I use. It speeds up the process so much that the LnL became cumbersome and unnecessary to me. I keep a needle on my old trigger gun, otherwise it never gets used. I don't even own a lever gun.
   / locknlube cupler for a grease gun #316
I mailed mine to "Murph", a member here on TBN.
   / locknlube cupler for a grease gun #317
Just gave it to him or did he modify it for you so it would fit the smaller holes?
   / locknlube cupler for a grease gun #318
Just gave it to him. I don't think you could modify one to fit smaller holes without compromising it's function.
2018 CATERPILLAR 249D SKID STEER (A51242)
2018 CATERPILLAR...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
1269 (A50490)
1269 (A50490)
