Buying Advice Kioti DK45c
/ Kioti DK45c #1
Trucking Big Ben
1939 ford 9n and 2002 Kioti dk45c
Newbie here. Just bought myself a 2002 DK45c. I’m looking to put a FEL on it. I’m in South Carolina and looking for a good used loader that will fit it with the cab. Any suggestions? TIA
/ Kioti DK45c #2
You can try to find one at a tractor wrecking yard. Most people don't sell their loader separate from their tractor. On the other hand my next door neighbor probably would. His Massey Ferguson hasn't moved in fifteen or twenty years. Whatever you do I hope you're a whiz at metal working and fabrication. A loader would need adapted to your tractor.
/ Kioti DK45c
Thanks Roadworthy. I have found a salvage yard near me and have started that search. I’m not sure on which model and brand would work the best with the least amount of fabrication. The closest I have found is 800 miles away and it’s a direct fit. Problem is that the guy won’t ship it. That’s a long drive but it might be worth it to not have to do more than just bolt her up. I haven’t made up my mind yet.
/ Kioti DK45c #4
One that bolts on would be the fastest way to install it. How much is the loader? or you could call the dealers and see if they have one kicking around....
/ Kioti DK45c
I can get the kl1470 for $2500 but I’ve read mixed reviews.
/ Kioti DK45c #6
Honestly I have not read up on them whats is the problems with that loader?....
/ Kioti DK45c
Do you guys think a TYM lt550 loader would work on this DK45c?
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
PALLET OF HEAVYEQUIPMENT PRESSURE WASHER PARTS (A68842)
PALLET OF...
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
2010 BRENNER TANK PUP TRAILER (A67714)
2010 BRENNER TANK...
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
