Mechanical seal on firefighter pump
/ Mechanical seal on firefighter pump #1
tricky74
Member
Eastwind DFM254
I bought a used Regent fire pump made in Australia and it has a Kubota GS200 engine.
Seems to be working well after a little tlc but the seal is leaking behind the pump.
I have the front removed and can't get the impeller off.
It has no bolt in the front and I am guessing it is held on by a right hand thread.
The shaft turns anti-clockwise so I am turning impeller anti-clock.
Can't find any detail online. Have contacted manufacturer a week ago for a price and still waiting to hear back.
I have tried soaking in WD40, some heat on the impeller as it is Aluminium on a steel shaft, a bit of shock with an Aluminium punch,
and locking the impeller and trying to turn crank. I am worried the impeller is going to break.
Any ideas?
/ Mechanical seal on firefighter pump #2
if the shaft turn clockwise, then it has to be a left hand thread so the impeller don't spin off.. turn the impeller clockwise to get it off, most pumps have a left hand thread on the impeller and shaft anyway..
I just realised I typed that wrong so will edit.
Shaft turns anti clock.
I did also try going the other way as well.
Have emailed manufacturer but who knows when they will answer.
/ Mechanical seal on firefighter pump #4
aluminum on a steel shaft tends to corrode so badly, that it's like they get welded together.. anti-seize compound can prevent that, but it's not always used, since manufacturers like selling repair parts!..
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
Kubota BH77 (A64126)
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
