Quick disconnect that isn't
/ Quick disconnect that isn't #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
I am having lots of trouble with the push-in, pull-out disconnect to the point that I've tried for an hour to get it unplugged. I managed to get the top one unplugged, but the bottom one isn't coming out. I finally gave up and got my wrenches and the hose is off, but the plug is still in there. Bump the lever and I'll lose a lot of oil.
So, 2 questions:
1) how do I get the plug out? I used to be able to get it out but I'm not as strong as I used to be either and unlikely to get stronger than I am now.
2) Is there an easier to use connector that will fit in here? I have a series of connectors on the fender with the collar that you slide back to connect/disconnect and those work much easier for me.
I plan on visiting with my JD dealer this week to see what he says, worst case: I'll have to fab up a whole new configuration with a new bulkhead connection.
/ Quick disconnect that isn't #2
My guess is sleeve that's designed to move on barrel to allow male fitting to disconnect/connect is dirty/rusty. I suggest to apply some penetrating type oil such as PB Blaster or Kroil to exterior of barrel. Have you attempted tapping sleeve with a small hammer?
/ Quick disconnect that isn't #3
Judging by the rust everywhere else and lack of grease on grease fittings no connector is going to last for you.
/ Quick disconnect that isn't #4
Rust? All I can see is dust from working with dry clay soil.
/ Quick disconnect that isn't #5
If there is still residual pressure in the lines the couplers will be difficult to disconnect. With the tractor off, operate the lever both directions to release pressure. If there's weight on a cylinder, let it down before disconnecting. If the tractor sat for a while you may need to bleed off pressure that builds up as the oil expands from heat.
There are two kinds of action for quick connects: the 'breakaway' type where the release sleeve on the female end can be moved either in or out to release the male coupler, and the regular kind where you have to move the sleeve outwards to release the male end. The idea with the breakaway type is that the sleeve gets attached to the tractor (they make clamps for that). Then if something pulls on the hose hard enough it will release the male coupler, saving the hoses from damage.
It's hard to tell if yours are breakaway type or not. The mount looks like it could be but it looks like there are steel lines to the female ends on the tractor. Female breakaways need flexible lines since the coupler body moves. But if they are breakaway type you can pull on the male end and it'll come out, and just push it in to connect.
Some coupler models have stiffer springs internally and on the release sleeve than others, making them harder to operate.
/ Quick disconnect that isn't #6
The female coupler looks like a "true" breakaway coupler which is why it works with the steel lines. All the moving parts are internal. Try pushing in and then pulling out all in one quick motion.
You might need to reconnect the hose to be able to do that.
Good luck. ;)
The connector is the breakaway type. There is a sleeve between the outside barrel and the connector that slides in and out. I'm supposed to be able to push it in and yank it out. I can push it in, but can't seem to yank hard enough.
The "rust" is actually very fine clay dust that gets EVERYWHERE and stays airborne for a long time, including the house so I try to keep the grease points wiped off. The dust is so bad at times I have to wear a mask.
I have run into the problem with pressure in the lines before so I do make sure all the pressure is released before I disconnect things. Sometimes it takes multiple back 'n forth on the lever to release the pressure.
Maybe this is the answer. I can try putting the hose back on and just driving off (slowly) to see if it disconnects. It's attached to an 800# grapple so I would think that should be heavy enough to pull it loose.
/ Quick disconnect that isn't #8
Ditto....
If "O" ring are involve they could be going bad and gummed up and forming their own "lock"...
Dale
/ Quick disconnect that isn't #9
Make a slide hammer. That fitting has NPT threads. Get a length of black pipe and a Tee fitting. Then get a shorter length of pipe that fits over and use it as a slide hammer.
Heck, just make a Tee handle out of black pipe and pull on it.
Once apart, liberally flush with spray lube between the body and sleeve.
/ Quick disconnect that isn't #10
I'd tend to go with this one. First, I'd spray the sleeve with a penetrating lubricant (WD40 or a lanolin based product) and let it penetrate for a while.
Next, turn the tractor off and work the hydraulic control for those 'lines' in both directions to release any pressure. Then, hopefully, the coupling will release.
Do the opposite procedure to connect. (Tractor off, work the control, connect)
/ Quick disconnect that isn't #11
You are missing the fact that the male/ female halves are currently connected without a hose attached on one side. There cannot be any pressure. This is a mechanical problem, not hydraulic.
/ Quick disconnect that isn't #12
If you think the single hose with male tip can't have pressure on it evidently you're not familiar with a single acting AKA one-way cylinder which can have hyd pressure on hose/connector.
/ Quick disconnect that isn't #13
Read the first post again. The OP disconnected the other end of the hose that is stuck.
/ Quick disconnect that isn't #14
I wonder if the male and female halves are not the same type. There are at least three "ag coupler" standards.
I think the way to check this would be to find the numbers printed on each half and track those models down to find out which they are.
/ Quick disconnect that isn't #15
/ Quick disconnect that isn't #16
I believe that to get the 2 halves separated you are going to have to reconnect all hoses! Go through the releasing pressure procedure again after ensuring that all loads are unloaded. The clay could have created its own seal if moisture got to it inside of the connection. With enough applications of penetrating oil this should be able to be washed out. Spray it every few seconds until you longer have any dust color dripping from the connection. Rotate the connection hose end while spraying to help to break up the clay. Use a wrench or pliers if need just being cautious with the force. Wiggle clockwise and counter clockwise should ensure that any ‘connection lock’ is freed.
Ok, here's an update. The connector threads are not pipe threads, they appear to be ORB. I can thread an NPT female onto the ORB male, I can not fit an NPT male into an ORB female. I'm aware that single lines can have pressure in them, I've used double acting valves to run a single acting cylinder before. But, there is no pressure in the line, oil is dribbling out of the connector because I'd unthreaded the hose from the connector since I had several things that had to be done sooner than later so the connector got put to the side for a little while. So, when I got back to it, I put a strain relief on the hose and reconnected it to the tractor and tied the strain relief to an 800# weight. I dropped off the mower and got ready to pull, but before I did I had my wife come out and help me. - Just one more time, she and I:
1(get ready), 2(push in), 3 ( pull out) and it popped right out, just like it's supposed to.
Bottom line on this seems to be that I'm right on the margin of being strong/weak enough to get it disconnected.
/ Quick disconnect that isn't #18
Glad to hear you git it apart with a little help! Several years ago, I broke a wrist and crack several ribs in an accident. More due to the ribs but the cast on the arm did not help in trying to do anything, so I understand well that frustration.
/ Quick disconnect that isn't #20
Had you lubed it? That might have helped too.
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2020 John Deere 333G High Flow Compact Track Loader Skid Steer (A61567)
2020 John Deere...
UNUSED KUBOTA M1886-96" QUICK ATTACH BUCKET (A62130)
UNUSED KUBOTA...
2015 19ft. Yamaha SX190 Boat with 17ft. S/A Boat Trailer (A61569)
2015 19ft. Yamaha...
(APPROX.20) UNUSED RAYSKY GROUND PROTECTION MATS (A62131)
(APPROX.20) UNUSED...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
