4310 drive line clunk when in 2WD
   / 4310 drive line clunk when in 2WD #1
Mike_ONeill
Member
Lucinda PA
JD 4310
Tractor is a 2003 model 4310 eHydro.
Especially when turning, it sometimes feels like it is in 4WD when I have 2WD selected, then I will hear a clunk noise and feel a slight jolt. I suspect the MFWD is not fully disengaging and the jolt/clunk is when it lets go. This happens often, even if 4WD has not been used for a while. The issue seems to be gradually getting worse.
The cylinder that disengages MFWD has about 3/4" stroke, which doesn't seem like much. I removed the pin joining the cylinder to the lever, and can easily move the lever about twice as far in the "disengage" direction.
The tractor was split open early last year by the dealer to replace a broken range shift fork. I don't know whether that has anything to do with it.
What should the stroke of that cylinder be? Any other ideas?
Thanks
   / 4310 drive line clunk when in 2WD #2
remember ALL the front drive systems turns regardless of whether the 4WD is engaged or not, you might jack up the front end and turn both the front tires by hand and see if you feel anything. You could have a bearing or gear failing in the final drives.
   / 4310 drive line clunk when in 2WD #3
A clunk sounds like a U-joint. Check those too.
   / 4310 drive line clunk when in 2WD #5
   / 4310 drive line clunk when in 2WD #6
What I found too. A place to start looking for the "clunk".
   / 4310 drive line clunk when in 2WD #7
Is it possible to remove the driveshaft without an oil leak from either the trans or front axle? If so, that might help to find the clunk, when jacking up the front and turning the tires by hand.
Thanks for the replies. Front wheels and driveshaft all turn smoothly by hand.
The local Deere service manager could find no specs on what the stroke of that cylinder should be. The Deere technical manual doesn't give it either. It appears to be a spring-return single acting cylinder. The second port on it is low pressure and looks to be a return line for any leakage past the piston.
I removed the pin linking the cylinder to the lever and turned the driveshaft with one hand while holding the lever with the other. Could feel the spline teeth of the shift collar starting to engage with the lever right where it would be with the cylinder extended (2wd position). The yoke is threaded to the cylinder rod.
So I turned the yoke one turn in the extend direction, locked the jam nut, and it seems to be fixed.
   / 4310 drive line clunk when in 2WD #9
Check the front trunion thrust bolt. They cause clunking when they loosen up, the the whole front axle slides back and forth
   / 4310 drive line clunk when in 2WD #10
arlen4720
You may have a good call on that trunnion thrust bolt. Reminded me of a similar clunk when that adjustment bolt was loose in my 4300..
Key # 31 bolt and locking nut #8
There are two, for and aft of the axle.
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
