Joyang Hydraulic Pump
/ Joyang Hydraulic Pump #1
rollk
Kioti CK30H
Hi all. Does anyone have any insight into the Joyang Hydraulic Pump that is used in some CK30 tractors? Kioti in NC tells me there are no seal kits for these pumps. My tractor has been out of commission for several months as I try to find seals.
/ Joyang Hydraulic Pump #2
Take the pump to a hyd shop that rebuilds them and see what they say....several months is way to long to be broken down........
/ Joyang Hydraulic Pump #3
Reach out to manufacturer and ask for seal sizes and maybe you can find elsewhere
I’m thinking mostly o-rings?
/ Joyang Hydraulic Pump #4
I concur with Peter's recommendation. Just in my small town, we have 5 shops that handle hydraulic hoses, hydraulic connections and hydraulic pumps. And don't buy from Kioti due to high price.
All very sound advice. Local hydraulic shop can't find any e-seals that fit. O - rings would be easy by comparison!
/ Joyang Hydraulic Pump #7
Got to be a way to get seals.
I’d reach out to manufacturer
That’s what I did to find seal size for my backhoe valve body.
There’s got to be others out there
Also maybe you can buy direct if nothing else
Joel
/ Joyang Hydraulic Pump #8
/ Joyang Hydraulic Pump #9
Welcome to owning a Kioti. It cost me $2,000 for a new pump for my DK55 because Kioti does not sell service parts for their tractors and the pump manufacturer would only tell me to contact kioti.
/ Joyang Hydraulic Pump #10
Sorry to hear about your situation. Could you tell us what year and how may hours on your Kioti? What were the symptoms ? Good luck, Dutchy
My Kioti is a 2014 CK30 H. At moment it has 226 hours on it.
This all started because the housing of the hydraulic pump is aluminum and I could not keep the bolts from loosening up. Thinking I had a bad seal I pulled it apart - only to find that the company had sent the wrong kit. This happened twice. On second teardown I tore one of the e seals. Here I sit. If this happens to you - put an expensive Timesert in the first time you take the pump out. Lock tight won't prevent the aluminum threads from stretching over time.
/ Joyang Hydraulic Pump #13
Interesting. I have the same year as yours, but almost double the hours, and would like some more info on which bolts that you are talking about so that I can check those bolts on my CK30. Can you add a picture of these bolts or describe in detail which bolts caused the issue for you? Sorry to bother you and hopefully you've got it fixed soon, Dutchy
My pump is at a hydraulic shop for the last few months as they try to find parts or build new pump with NA parts. There are four long metric bolts clamping the pump case together. Two would stretch the aluminum threads in the pump case, possibly as a result of heat expansion and subsequent cooling. If you catch it quickly enough you can insert timeserts into the aluminum or have a hydraulic shop build a new head end for the pump out of steel.
/ Joyang Hydraulic Pump #15
Where are these 4 bolts that you speak of? Are they external so that they can be checked? Has Kioti offered to help you out in any way? Thanks, Dutchy
The four bolts are on the outer flanges of the pump. They can be accessed with some difficulty behind the right loader bracket, below the dash/fuel tank.
43024 (A59228)
43024 (A59228)
2011 Case IH Magnum 315 Tractor (A64047)
2011 Case IH...
Caterpillar 259D3 (A62180)
Caterpillar 259D3...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61567)
2017 Bad Boy...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
