Rear wheels binding
/ Rear wheels binding #21
Fireman, if Hoye or Leonard can't locate that R&P then possibly this guy out in Ernie's old neighborhood might have a lead on additional salvage tractors. He doesn't have a FX265 but he might know someone else in the business. He did right by me for an axle housing last year, fair price and shipped soon. Or maybe this information can help someone else.
Tractor parts! Dismantling diesel farm tractors, new arrivals...
/ Rear wheels binding #22
/ Rear wheels binding #23
Ernie, does that sound like enough stress to tear teeth out of the R&P?
Is this a common problem for the FX generation?
I wonder if Fireman was sold a tractor that had broken teeth glued back temporarily with JB Weld or something. I don't see how a trailer deck could give enough traction to destroy that.
Cal, it happens a lot to the FX models. What happens is, the operator shifts either forward or reverse while the tractor is mowing in the opposite direction which creates a great amount of stress on the R&P and whamo they crack or break off a tooth.
Early on I was warned against doing that by my supplier in Japan, so I always stopped to shift from forward to reverse and never had a problem.
But there are folks out there that get in a hurry, and it kept us in business for a long time repairing them.
So is there a way to diagnose this without tearing the whole thing apart? What else could cause the problem besides the R&P? Where can I get a service manual for this unit?
I'm so bumbed. Thought this was going to be a good tractor.
/ Rear wheels binding #25
Fireman, There are no service manuals, there are only parts manuals, you can buy one from Hoye tractor.
What else could be the problem? Well you're going to have to pull the top end off and have a look inside to see.
You have the best people to help you out right here at TBN
Make it a weekend project, can you turn a wrench?
I can. A little daunting because I have never torn into one before. Is there anything I should watch out for?
Strangely enough last night while messing with it, it freed up and stopped binding up. I had shifted gears a few times and into out of 4 wheel drive. There is still some slop but not binding. Drained some oil out and there was no metal that I could see. Could a scope see anything worthwhile before tearing it apart.
/ Rear wheels binding #27
If you take it apart take a lot of pictures, they will help you when you start putting it back together.
Not familiar with scopes and don't know how you could direct one around in there.
/ Rear wheels binding #28
MAYBE, the broken parts have fallen to the bottom of the casing and are not binding anymore.
Either way I would open it up and have a look, to prevent any further damage.
You want to remove the top off the rear axle, the case that holds the lift arms, its some bolts and some guide pins to hold it on.
If you can pressure wash it first or clean it up it makes it more pleasant.
/ Rear wheels binding #29
If you are familiar with using a scope and familiar with what you are looking for (what your R&P looks like) yes you can gain a lot of information from a small opening to get the bore scope into the cavity.
If you are not familiar with either one it will be a experience in frustration in my opinion.
Bore scopes give a ‘fish eye’ view (very wide angle view) which can distort the picture. In addition there are lots of gears and shafts and gears that you must work around, this can be frustrating also as well as requiring patience with the bore scope.
But if you can get a parts diagram to get a feel for where in the casing you need to look and have experience with a bore scope (or know some who does) then give it a try.
Now all that said, you are going to have to tear into it at some point if you plan to fix it, so taking it apart to look is a step to fixing it.
Thanks everyone!
I will make a plan for after the 4th to open it up.
If anyone has info on parts for this model please let me know. So far coming up dry.
Have a great 4th everyone and I'll check back in when I start.
/ Rear wheels binding #31
Thanks everyone!
Maybe,, I missed it,, but, the FIRST thing I would do is jack up EACH tire, individually, and spin that tire.
If there is a high, low range, put it in neutral.
Notice if one tire is more difficult to turn, than the others,,
Your problem might be as simple as a defective bearing, or a rusty universal joint,,
There is a LOT of diagnosing steps,, before "opening it up",,, IMHO,,
/ Rear wheels binding #32
That's good advice. It sounds and acts like my wife's Subaru when a front wheel bearing failed.
/ Rear wheels binding #33
I think that way about diagnosing first too, that's why I posted a testing format back in post #5 ..... I figured it would help get a start on diagnosis.
But I wasn't surprised to find that many prefer speculation to diagnosis - especially on a forum.
That it didn't surprise me also because I had already learned it back when I had a half dozen mechanics working at my repair shop. At first it took me by surprise that some good mechanics were of the "take it apart to see what is wrong" school of diagnosis. It took me a while to figure out how to deal with it.
My problem was being a "diagnosis first and wrenches later" kinda guy, it surprised me how many decent mechanics people don't do much diagnosis at all. Being a young shop owner and sure I was right, I constantly tried to get all the mechanics to at least try to diagnose first and tear it down based on what they learned. But not very successfully.
The "just tear it down and see what you find" type of mechanic was equally adamant that the proper way to do repairs was to just start in somewhere close to the problem and progressively take things apart until the problem was found. The ones who worked that way did OK, and I noticed that they had less of a problem than the diagnostic bunch in defending their resulting hours on the repair bill - always a problem for a shop owner.
The other thing I noticed about the "tear it down" group was they tended to avoid electrical & cooling system work and preferred straight mechanical. They were particularly good with gearbox and drive train work. I guess that's not surprising either.
rScotty
I spun each wheel. They both spin fairly easy till it catches. The catch happens with both sides while in neutral. I can spin about 1/4 turn on the wheel before it catches again. Screenshot_20200702-125557_WiFi Look.jpg
/ Rear wheels binding #35
Not sure what I am looking at, is that a broke tooth?
Ok I got a scope inside. Ring gear is trashed. See video. Now I need to find parts. Anyone know what it would cost to machine one if I can't find one?
2;):p213441.mp4 - Google Drive
Pinion gear but the outside housing looks like it's been cracked off. Thre video shows the ring gear and it is missing several teeth.
/ Rear wheels binding #38
You might be in the place where you search high and low for parts. If None available, sell it for a parts tractor.
I just bought it unfortunately. Would like to keep it if I can.
/ Rear wheels binding #40
I have no idea where to go to look for parts, but Yanmar must have built thousands of that model. Where were they sold?
BTW, if it were my project, I'd be looking for a whole rear axle assembly. It's going to be used, and the whole assembly may be less than the parts.
Now that you know what you are looking for, are you still going to tear it apart? Or leave it together until you find the replacement parts?
rScotty
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
APPROX (9)PIECES OF 2'X11' CORRUGATED METAL SHEETS (A62131)
APPROX (9)PIECES...
40' CONTAINER (A62131)
2014 Ford F-550 4x4 Service Truck with Crane, VIN # 1FDUF5HY9EEB69513 (A61165)
2014 Ford F-550...
2010 Dodge Charger Sedan (A61569)
2010 Dodge Charger...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
