New shop build, Doneish but continuing shenanigans
   / New shop build, Doneish but continuing shenanigans
Made progress the last 4 days, took 2 days off work for things to line up and worked my rear off... A friend came over yesterday and helped out, we got 13 of the posts into their holes and just have the one for the lumber hole left to stick in but it will be easier... From there we got the corner posts squared and gravel tamped in those . Today I marked the strings for the center line of the rest of the posts and found out I had measured wrong for the box in the lumber hole and the post would have been right on one of the corners, so I reworked things and added 5 more 80 pound bags of concrete... that makes 58 80 pound bags. Combine that with lifting the posts in by hand I didn't have much left to give today, I did get two more posts set with gravel, so 6 posts are set right now, 8 more to go.
We used the tractor to set one of the posts, the density varied greatly on the posts, the second one we did seemed heavier but we started off hefting them off the ground then pushing them up, the rest we started about 18" up and that seemed to help.
I'll try to get a couple pictures up later.
One question, I'll research it more, but on the skirt boards I have 2x8's and am planning on a 6" slab, would it be better to have the concrete to the top of the skirt board or 2" down?
   / New shop build, Doneish but continuing shenanigans #82
On my pole barn when I pour the floor it will be at the top of the skirt boards because that's the bottom of the man door.... It's a Morton built barn......
   / New shop build, Doneish but continuing shenanigans #83
What we did is we added one to the inside. That also gives you something to strike against when you pour your floor. Ours is not heated and we did not what the concrete grabbing onto the posts. Then we filled that area in with gravel, so in our case we held the skirt board up about 2 inches. However, you do it you do not want any concrete getting under the skirt board or grabbing onto your poles. When the ground freezes that building should stay right where it is, however your floor could move. That is the thought process anyway.
I think I've seen single digit temperatures twice in my lifetime in this area, the frost level is high enough that it isn't in any codes around here... The plans call for nails at every post to attach the posts to the slab so it's the opposite of what you are talking about. The only concern on this property is the ground water level, it is around 5' deep right now, and was at least a foot higher a month ago....
   / New shop build, Doneish but continuing shenanigans #85
Then you are going to want to put a vapor barrier under your concrete! I would then put an inch or two of sand on to level, protecting the plastic and pour on top of that. I wished i would have held my skirt board higher. It is nice to have it at the level to pour your concrete at however two inches above so stuff doesn't slid into outside steal denting it is nice also.
   / New shop build, Doneish but continuing shenanigans #86
Install your skit board level with the top of the concrete. Pour your concrete and then add a 2 x 2 screwing it to the skirt board.
   / New shop build, Doneish but continuing shenanigans #87
Morton built our 30x50 pole barn 2 yrs ago. They left it up to me to where i wanted the top of the concrete floor so they knew where to put the 2x8 skirt board. I came down 2" from top of skirt board. I also have the floor sloping to the front on a 1/4" per 10' slope. I just snapped a string line on the skirt board so the concrete crew knew where the top of the floor was. I had a extra add on of 7/16" x 32" OSB panels installed on lower portion of the exterior walls. It keeps the metal siding from getting damaged from inside. The 2x8 skirt boards are rabbited to allow the 7/16" panels to be flush .
   / New shop build, Doneish but continuing shenanigans #88
I'm OCD about water. I'd never want floor water to reach my metal.
Skirt board above concrete. Inner wall covering gapped 1/4" above concrete. Crack caulked.
   / New shop build, Doneish but continuing shenanigans #89
Well if that is the case hold the skirt board high and put a 2 x 4 down 2" won't need nails into the concrete the slab moves it is going to push on that wall for sure.
I've been trying not to post every little step, but I'm making progress and am building vertically now! Two weeks ago I got the skirt boards up, I made a water level with 55' of clear hose and marked all 14 posts with a mark at the same height, then nailed the skirt boards up to the line from that height. Last weekend I got the last of the skirt boards up, the hole drilled for the man door drilled and the post set, got the lumber hole filled to the point where I ran out of gravel (it's about 1' deep now). On Sunday my brother came over, we put up a row of girts and we moved the trusses into the building and stood all but 2 around their posts and attached enough perlins to keep them upright. Right now the outer trusses are just attached to two posts each with some duplex nails.
Tonight I got the perlin boards on one end truss and one of the pairs, tomorrow hopefully the other pair that's standing and the other end truss.
Of course every step gets complicated... I lost most of a Saturday trying to get my secondary air compressor running, turns out I had two bum motors not just one, got a replacement but the Harbor Freight motor had a 7/8" shaft instead of 1/2" being an 1800rpm motor instead of 3450rpm... so I just ended up stringing 200' of air hose from the garage and ordered a pulley on Amazon, now that part works :). Then I had to get the one man post hole digger running, after that had to get the auger working since it's teeth were SHOT, took the easy route and just built up some material with 7018 welding rod since I didn't feel like attempting to find Penko teeth wasting more time...
Progress, I have truss jacks lined up for Saturday, should have the trusses in their home then, will see how far I can get with help on site... the material piles are getting smaller finally!
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
2018 Ram 5500 4x4 Crew Cab Utility Flatbed Truck (A55973)
2018 Ram 5500 4x4...
DEWALT CHOP SAW (A58374)
DEWALT CHOP SAW...
Auger Drill Bit (A56857)
Auger Drill Bit...
KIOTI SL7504-PL SKID STEER (A52709)
KIOTI SL7504-PL...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
