3-Point Hitch JD 2130 load control arm fouling load shaft install
   / JD 2130 load control arm fouling load shaft install #11
Your pictures do not look like the 540-1000 PTO.
Have you looked forward of the right sway block ?
Look in yellow highlighted area
Yup, that's what I thought as well. Wondering if the red dot I have highlighted which is a hole in the casting is the access point to it? On night shift so won't get a chance till tomorrow arvo to have a look at it. It lines up pretty well with the top link mount so it makes sense to be there. Also, I don't think it is a multi speed PTO either. Looking at pictures it looks like the other shaft lives in the casting beside/behind the top link mount.
   / JD 2130 load control arm fouling load shaft install #13
Yes that's the hole I was referring to. I agree with Zebrafive that Ausmac's tractor has 540 only pto.
Well would you look at that little bugger hiding in all the dirt. I would have never looked there. So give it a soak in lubricant and see if it moves for me tomorrow. Also, have a go at the quality of the repair I found this arvo. I don't know how they managed to break this but that is some of the worst welding I have ever seen. Will be fixing that up before making any adjustments as I would say that probably has something to do with the control arm being in the wrong position.... It will be made right eventually!!!
   / JD 2130 load control arm fouling load shaft install #15
Yepper you found the adjusting screw. I will advise to turn screw in by small increments until shaft can be installed.
That is the plan mate, however I want to remove the screw first to see if I can clean it up as I do not think it will screw in by the looks of it. May just buy a new screw, nut, o ring but then I have to wait another ? Amount of time for parts.
Would anyone know the thread size for the negative stop screw by any chance? Thinking I can borrow a tap/die and clean it up if I could find out the size.
   / JD 2130 load control arm fouling load shaft install #18
1/2"-20 threads/inch
   / JD 2130 load control arm fouling load shaft install #19
Screw is listed as no longer available from JD parts.
Nut is P/N 14H856, it's a 1/2-20 jam nut, or 1/2 nut, takes 3/4" wrench 5/16" (.323") thick
O-ring is P/N A4365R, same as number 010 standard O ring, .239" ID and .070 diameter stock.
Thanks Zebra, same part numbers I found. I also found the screw to be T23216. Shame it is not made anymore. I will get a tap and die and clean it up best I can. Nut and o ring will be easy enough to find. Just have to get it out in one piece. It looked pretty ugly today.
UNUSED FUTURE X-PG44" HYD MINI PLATE GRABBER (A57193)
UNUSED FUTURE...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
1996 INTERNATIONAL DUMP TRUCK (A57192)
1996 INTERNATIONAL...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
