3-Point Hitch JD 2130 load control arm fouling load shaft install
   / JD 2130 load control arm fouling load shaft install #21
Since the screw was NLA, I did not post the P/N
A dealer search might turn up the screw T23216. Dealers can search other dealer's parts inventory.
Hopefully you wont need one. If you do, tractor salvage yards may have one.
Well being worried as I was, the job got completed today. The hardest part was getting the negative stop screw out. Boy was it rusted in good. When out I cleaned it out and tidied up the threads and moved the control arm back. Not much but enough. Installed seals, put 3pl back together and then filled oil. Set up the 3pl as per TM and it is spot on in all areas that I can see. It was way out in a few places, hence why it would only lift properly in LD and not D. Have not had an implement on yet but no leaks on the shed floor. Thanks to all that helped, it made a huge difference. Next up fuel gauge but I am happy with a stick for the time being. When I get time I will attack that. Cheers! (PS, it has not had an implement on, but to get the 100kg load on the draft arms to do the set up we had an 80kg person holding a 20kg bag of cement standing on the draft arms!).
   / JD 2130 load control arm fouling load shaft install #23
You're welcome. I'm glad you got L/D control adjusted & operating correctly.
Jim
   / JD 2130 load control arm fouling load shaft install #24
I like your way of making a 100kg load :thumbsup:
Ha ha thanks Zebra. I thought I want to get this exact so even my implement was the exact weight the TM specified.
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2023 GMC Sierra 2500 HD Crew Cab Truck (A59213)
2023 GMC Sierra...
Giyi 32' Rake (A57149)
1991 Ford L9000  2,000 Gallon Water Truck (A59213)
1991 Ford L9000...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
