Truck Code Reader Recomendations
   / Truck Code Reader Recomendations #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
I need to get a Code Reader for a 06 Duramax 4x4.
I am sure a lot of you have them in the toolbox and use them. Looking for a reasonable priced unit to help diagnose current and future issues with my truck.
What is your go to reader??
TIA
   / Truck Code Reader Recomendations #3
I run the Scanguage II on both my 1 ton fords, can be customized for different readings
and will pull and reset codes as needed
>> ScanGauge II
   / Truck Code Reader Recomendations #4
Avoid low end plugin blue tooth/wifi/cell phone apps units... Just bit the bullet and spend $75 to $100 (or more) for good direct plugin unit... I have a ELM 327 and Android app, some days it works and some days it is absolutely miserable to get it to read anything.... Those day I have to trudge over and borrow neighbors $89 unit...
Dale
   / Truck Code Reader Recomendations #5
Pretty much anything Autel works ok even though their junk is stolen intellectual property because hey, that's how the Chinese do it!
   / Truck Code Reader Recomendations #6
i'd second the Scanguage. Handy for both getting codes and using as a gauge for other things while operating if needed (like trans. temp, egt etc depending on vehicle)
   / Truck Code Reader Recomendations #7
Always copy the preferred features and discard the others. I have an Autel as well. Good OBD scanner. Chinese ain't stupid.
2008 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52705)
2008 GENIE...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2013 Jeep Patriot Sport 4WD SUV (A55758)
2013 Jeep Patriot...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A54865)
2008 IC...
