Buying Advice 1025R vs 3046R
/ 1025R vs 3046R #1
lloyd5115
1025r
I am new to tractors. we bought 20 acres in central illinois 2 years ago and we bought a brand new 2018 1025R, I bought this mostly for mowing. I have since bought a zero turn lawn mower, so I dont use the 1025r for mowing. and now some of the chores I have around my property the 1025r is struggling with. My 1025R has 39 hrs on it, I have the lower mower deck and a box blade. I want to trade it for a 2016 3046R with 400 hours on it. they are offering me $13000 for my tractor, and they are asking $25500. the 3046r has turf tires on it. I really no nothing about this so My ? is this a pretty good deal.
/ 1025R vs 3046R #2
Does the 1025R have a loader? Does the 3046r have a loader on it?
/ 1025R vs 3046R #3
$13K sounds good for your 1025R. I friend bought a used 1023E with loader, deck and rototiller that had 100hours for $13K Since you did not mention a loader, $13 sounds like you are getting a good price for yours.
No idea on the 3046R value.
/ 1025R vs 3046R #4
I believe I found the 3046R on tractor house. I have not seen many 3000 series tractors rear wheel weights on them.
It looks like a new tractor. That looks like a good deal to me.
/ 1025R vs 3046R #5
Subcompact and relatively narrow stance compact tractors under 3,000 pounds bare weight operate in landscape, kitchen/commercial garden or hobby farm applications on one to ten flat acres.
If your are going to farm twenty acres consider a Deere model 1,000 pounds heavier than 3046R model. A 3,900 pound bare weight tractor approximately 66" wide will be able to utilize 72" wide implements rather than 60" implements.
Tractors are inherently unstable operating on sloped or uneven ground. Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability. Rear axle is the tractor component on which rear wheels/tires mount. A 6" to 10" wider rear axle substantially decreases tractor rollover potential. Tractor rear tread, the distance from the center of one rear tire to the center of the other rear tire, is an approximation of rear axle width.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
John Deere 3046R - dimensions
2014 - 3R Series
Compact Utility tractor
Previous model: John Deere 3720
Series back: John Deere 3039R
John Deere 3046R Tires:
Standard tires (ag): Front: 7.00-14. Rear: 11.2-24
Dimensions:
ROPS Weight: 2900 lbs [1315 kg]
Cab Weight: 3570 lbs [1619 kg]
Front axle load: 3196 lbs [1449 kg]
Rear axle load: 4410 lbs [2000 kg]
Wheelbase: 68 inches [172 cm]
Height (hood): 57 inches [144 cm]
Height (ROPS): 93.3 inches [236 cm]
72 inches [182 cm] (folded)
Height (cab): 85 inches [215 cm]
Ground clearance: 12.2 inches [30 cm]
Front tread: 44.9 inches [114 cm]
Rear tread: 40.6 inches [103 cm]
/ 1025R vs 3046R #6
If the 3046R has a loader, it sounds like a good deal. The list price for new with loader is about 38K. Without a loader it's about 32K so not such a good deal. Also, you absolutely will need the loader. My only concern would be the turf tires. For general work on 20 acres, they aren't nearly as good as R4s or R1s.
/ 1025R vs 3046R #7
20 acres. Go with 3046R. You'll wear your smaller machine out if your using it all the time. Not sure what work and chores you are doing exactly. However, recent example, I rented a man lift and took down a 60ft elm tree. I have the 72" 4 and 1 bucket. Cut the big limbs up into 7 foot chunks and hauled it off to be burned after it dries. Trunk was cut into 3.5-4 ft lengths and maxed out the tractor when moving. Branches are already ash. No way I could have done that with a smaller unit..er...tractor. Often times I wish I had a smaller tractor (with bucket) to jog around the yard for various, less massive, things and not have to worry about weight etc, but the capacity and effectiveness of the larger machine far outweighs the desire for the smaller one. Unsure if you are east (black soil) or west (more sandy soil), but if anywhere near east and you want to do dirt work, again weight is your friend. How's it go here? Figure out what tractor size you need and then go up 1 size and you will not be disappointed. Don't get me started on what can be done with pallet forks. There are whole threads here for that. Again, bigger machine = more options for moving heavy stuff.
/ 1025R vs 3046R
Thanks for all the advice. Sorry I did not mention that both tractors have loaders on them. My property consists of mostly wooded area, approx %75 of my land. so sometimes moving large fallen trees. I am about 20 miles east of effingham il. seems like a lot of my land is clay.
/ 1025R vs 3046R #9
Hey Lloyd, sounds like you are near where I grew up. Neoga or Toledo? Send me a PM.
/ 1025R vs 3046R #11
Sounds high to me if it is not a cab tractor. My brother bought a Brand new 4052m loader and dual rear remotes for 28500 earlier this year. Trade price for your 1025 is good. I think I would shop around a little bit. 3 series are not real stable on slopes. My buddy has the 3046r with cab and loader. We put 4 series 5 inch spacers on the back. Help stability a lot. Good luck on whatever you choose.
/ 1025R vs 3046R #12
I have a 3046R with cab and loader. Love it. It is a stout little machine. I only wish that it was wider.
/ 1025R vs 3046R #13
Hi Bear. Same here. Wish the thing was wider. I had heard that the tires/rims/wheels can be flipped making them wider. I asked the dealer to do that before they delivered. They said that it would run into the wheels on the mower deck so they wouldn't do it. For now, I don't use the deck and I want to give this a shot.
/ 1025R vs 3046R #14
For $8500, you could keep the 1025R and get a really good old tractor for larger tasks. MF135, Ford 3000/4000, Old JD 3020, etc. The old solid, simple tractors can be had for well in that price range and will offer way more utility.
8' DISC HARROW (A60430)
8' DISC HARROW...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
CHEVY 4X4 DUALLY TRUCK BED (A65643)
CHEVY 4X4 DUALLY...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
