   / Share Pics of People Hauling or Towing Something Wrong #12,621
A clip in the hole in the wrench so it can't come off and good to go.
   / Share Pics of People Hauling or Towing Something Wrong #12,622
Ummm. You forgot about the law of Gravity, it has to stay down, it's The Law!!
   / Share Pics of People Hauling or Towing Something Wrong #12,623
Looks like a pickup towing a farm implement like a grain wagon in the field. I suspect he forgot the hitch pin and is using whatever he had and will probably bend the adjustable "hammer". If he's going from the field to the barn, i'd let it go. On the highway, it's a, Nope!
   / Share Pics of People Hauling or Towing Something Wrong #12,624
Whatever it is, it appears to have a significant amount of negative tongue weight and it looks like it frequently has negative tongue weight is a point where the hitch is bent.
I'm not sure I would trust the welds holding the hitch to the tongue of a trailer.
Seems like there should be a little bit more weld there and a bigger hitch welded to the tongue.
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #12,625
Aaron Z
Interesting how a picture can be interpreted when we have incomplete information.
That negative tongue weight appearance could be due to the double axle trailer normally sitting that way. Mine will sit with the tongue off the ground by a bit but we don't have enough of the picture to see the angle. And the bent hitch could be due to it being welded that way especially with the rough cut appearance of the steel which implies a quick and dirty implementation. As for more weld material - I completely over looked that, but I agree.
   / Share Pics of People Hauling or Towing Something Wrong #12,628
So was mine, and I haven’t said it yet.
   / Share Pics of People Hauling or Towing Something Wrong #12,629
No picture because it all happened so fast and was on a 65mph highway in the opposite direction. I saw a smallish car with a slide open moon roof and a 9 ft sickle bar mower frame and cutter bar sticking straight up in the air and out of the moon roof. It had to be sticking out of the roof by maybe 6 ft. It was shocking, to say the least and I wish I had a picture.
It may well have been the whole mower inside the car but could have been just the sickle bar sticking out. Either way, I never saw anything like it. Guess necessity is the mother of invention.
EDIT--and they were going 65MPH
   / Share Pics of People Hauling or Towing Something Wrong #12,630
Maybe they turn the car on it's side to cut the grass ?
John Deere 6110M (A53317)
John Deere 6110M...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2008 Ford Fusion SE Sedan (A55853)
2008 Ford Fusion...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
Kubota ZG327 (A50120)
