I found a new use for the forks
   / I found a new use for the forks #1
orezok
Elite Member
Mojave Desert, CA
Kubota B7800
Easy way to drop 24" container Palo Verde into the hole.
   / I found a new use for the forks #2
It stays in the container?
No, I cut the bottom off the container before placing. Then I cut the sides off once it is in place. The only way to lift it without the ball falling apart is with the container
   / I found a new use for the forks #4
Got it! :thumbsup:
   / I found a new use for the forks #6
Need to remember this trick. :thumbsup:
2018 Doosan DL220-5 Articulated Wheel Loader (A55787)
2018 Doosan...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2015 Dodge Ram 1500 (A53314)
2015 Dodge Ram...
Giyi Mini Rotating Bucket (A53316)
Giyi Mini Rotating...
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
