Does tractor cab help with the noise level?
/ Does tractor cab help with the noise level? #1
budlite
Toney, Alabama
NH Workmaster 75
My hearing has degraded with age, I wear hearing aids and use Bluetooth headphones with noise suppression when operating any machinery. They help, but I have to turn the music volume way up and it's still very noisy. Would a tractor cab offer any protection worth the expense? Willing to consider buying new tractor if OEM is significantly better.
/ Does tractor cab help with the noise level? #2
My cabbed M is quiet enough to run without hearing protection and I can listen to the radio at normal volume
/ Does tractor cab help with the noise level? #3
I can talk on the phone while bush hogging. I do use a bluetooth headset with noise canceling to listen to music so I'm sure that helps some.
Overall, with noise, dust and bugs a cab is the best tractor investment I've made.
/ Does tractor cab help with the noise level? #4
Looking at your location, snowblowing isn't on the list. The cab keeps the noise level quite low. The AC would be most welcome in your heat, along with no bugs or dust.
/ Does tractor cab help with the noise level? #5
Yes,a cab helps, but not all cabs are created equal. Some do a better job than others, and aftermarket cabs are more for weather protection than nvh control, in my experience.
/ Does tractor cab help with the noise level? #6
Oh yeah I does! I was against a cab for many different reasons, but I am so happy I got one now. Dust, snow, noise, bugs, all stay outside. Inside, I can hear the tractor (obviously) but it's not deafening. I listen to podcasts while out working using the cab speakers. I dread the backhoe, getting out and on that thing to dig something, mostly due to the noise, bugs, and heat. The cab is not perfect, its tall, and made of glass. But for me, I am very happy I got the 'C' on the end of my tractor model. :thumbsup:
Thanks for the info guys, very helpful! A/C would be nice and the bugs in Alabama are quite plentiful, so those are a plus too!
/ Does tractor cab help with the noise level? #8
I have both. M9000 cab and M9000 open station. The OS tractor compared to the cab unit is like being in a machine shop with every machine running full blast. I'm continually amazed at the difference. Cabs aren't good for every circumstance however, why I have both.
/ Does tractor cab help with the noise level? #9
That's MY answer too, not all cabs are created equal!!
SR
/ Does tractor cab help with the noise level? #10
The distinct disadvantages are.. Will it fit in your storage space, not an issue with me, mine are in the barn and two and most importantly, if your property is wooded, you'll quickly dislike the cab. Wooded lots and cabs don't get along well and crashes will be expensive.
/ Does tractor cab help with the noise level? #11
My cab turned work into relaxation. It is not as quiet as I expected but it is much quieter than an open station tractor. The biggest difference is AC and no dust. I can bush hog all day get off the tractor and go to dinner. With my open station I need a shower to wash off the dust.
/ Does tractor cab help with the noise level? #12
Along with the refrigeration come another aspect, maintenance. All that dust and debris outside, some of it gets inside, inside the ac unit (past the cabin filter) and the ac unit will eventually need cleaned and most aren't really accessible easily and then there is the issue of refrigerant and refrigeration components so having a cab is nice but the long term care of them is much more involved.
me, I have both. Sometimes an open station is better, sometimes a climate controlled cabin is better. All depends on the situation.
/ Does tractor cab help with the noise level? #13
In my Kubota cab, I turn on the AC, turn on my favorite music channel and I hardly hear the engine unless I'm doing high RMP work
/ Does tractor cab help with the noise level? #14
My cab Deere 4720 is really quiet even mowing at 2400 rpm, air suspension seat, the radio is on - life is good.
/ Does tractor cab help with the noise level? #15
Cabs are not created equal as is hearing aids are not equal. Some people with hearing aids have issues with a room full of people talking while other's are not. Some cabs are quieter but have a low rumble echoing buffeting noise that you may not enjoy. The best thing to do are test drives at pto rpm.
/ Does tractor cab help with the noise level? #16
My LS cab is very quiet and after 10 years of ownership, everything still works and looks new. It is very tolerant of limbs brushing the sides and tops. Only thing that happens is the mirrors get knocked back against the door but no damage. It does make it difficult to open the doors with them folded backward. Much better for a limb to brush the cab than to brush me.
/ Does tractor cab help with the noise level? #17
My LS cab is very quiet and after 10 years of ownership, everything still works and looks new. It is very tolerant of limbs brushing the sides and tops. but no damage. Only thing that happens is the mirrors get knocked back against the door It does make it difficult to open the doors with them folded backward. Much better for a limb to brush the cab than to brush me.
Yes, that happens to mine also, a minor issue.
/ Does tractor cab help with the noise level? #18
Was doing some bush hog work yesterday. Yup, mirrors get pushed around, minor detail. Sooner that than getting beat up and poked in the eye with branches. Do enough ducking and dodging while mowing. My old Deines mower design doesn't fit well for a screen cage.
/ Does tractor cab help with the noise level? #19
My last hearing test was -90 dBc. Cab will reduce it but even with the JD "Sound Guard" cab, late 1970 issue on mine, it was noisy. Radio is a joke on it and current Branson. Hearing aids are a joke for me. Pick up everything but what you want to hear; wind especially a nuisance. On the auto adjust, the difference between hear and mute was too tight a band. Have had half a dozen pair, thousands invested, fancy digital this and that. Waste of time and money. I can get along just fine without them.
/ Does tractor cab help with the noise level? #20
Take one for a ride, decide for yourself!
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
New/Unused 2 Post Car Lift (A61165)
New/Unused 2 Post...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2017 Terex RL4 S/A Towable Light Tower (A60352)
2017 Terex RL4 S/A...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
