Ford 1715 clutch replacement
/ Ford 1715 clutch replacement #1
billkater
Olney, Il. Home of the White Squirrel
New Holland 1715
Hey all,
It is time for me to replace the clutch on my 1715 tractor. messicks.com has all the parts in stock. But I can not find the gauge for setting it. The manual refers to #FNH 1300 as the correct gauge. Where can I get one at?
I watched this video of a guy doing a replacement. He didn't use a gauge. But I would rather do it right the first time. Don't wanna split the tractor again.
Also, I found a complete kit from Yesterdays tractor for $102.... Ford 1700 Clutch Kit - SBA320450011K Anyone have any experience with their parts? Dont wanna split the tractor twice for cheap parts
Thanks for the help.
/ Ford 1715 clutch replacement #2
Hey all,
"Don't wanna split the tractor twice for cheap parts"
YOU ARE A LOT SMARTER that I was!
I bought cheap aftermarket parts, and did the job TWICE.
If you can buy ALL your parts from Messick's...buy ALL your parts from Messick's!
Messick's parts guys are GREAT!
They will tell you IF you need a gauge.
I think new clutches are generally shipped preset to specs.
/ Ford 1715 clutch replacement #3
I had to split my TC24D twice - once for a hydrostatic pump leak and then 2 years later for a clutch. I couldn't locate an alignment tool anywhere. I tried several different dealers and nothing. So finally went at it. I aligned the new clutch up with the marks on the pressure plate and bolted it down. Slid it all back together like butter. Been almost 3 years now without issue.
This isn't the alignment tool. It is the gauge to set the pressure plate fingers
/ Ford 1715 clutch replacement #5
Same here......no alignment tool...worked great!
/ Ford 1715 clutch replacement #8
Unless you have a fair bit of mechanical experience you have as good a chance of making things worse as better.
I have no problem fixing most anything. I just wanna do the best job that I can when I do it. I hate to shortcut things and then have to redo them. I will check with the closest Does/New Holland dealer to see if they have a gauge.
/ Ford 1715 clutch replacement #10
I've done the clutch on my 1715 twice. Second time because I did not use a OEM release bearing. Trying to remember where I got the pressure plate ... it was NOT OEM .... but I remember looking carefully at the OEM part and found an aftermarket part that appeared to be the exact same part, and on installation it did appear to be exactly the same as OEM .... bear in mind the 1715 had parts from all over ... I think both the aftermarket part and the OEM were both made in India. It came with an alignment tool, but no gauge. I checked the finger adjustment by eye, they all appeared to be the same so I just installed it .... has worked great. The lesson I learned was not to buy a discount release bearing, it lasted about two years.
/ Ford 1715 clutch replacement #11
I learned the same tractor split twice lesson!
Even though OEM parts are made overseas, I still will only buy OEM internal parts from OEM dealers.
Splitting a tractor twice, to replace cheaply made after market parts, is not my idea of fun!
/ Ford 1715 clutch replacement #12
Just checked .. I bought a kit from ebay that had very good reviews. I used the pressure plate and disk from the kit, but threw out the release bearing and pilot bearing and used OEM .... the pressure plate and disk appeared identical to OEM, the pilot bearing and release bearing were obvious no-name inferior products. One thing I did notice that was unusual was the OEM pilot bearing was only sealed on the outside, and the cheap aftermarket was sealed on both sides. So I put extra grease in the crank recess which should warm up with the engine and help keep the pilot bearing lubricated.
I'll consider aftermarket to save several hundred dollars assuming I can find parts that appear to be better quality than horrible chinese knockoffs ... but won't compromise on things like bearings that only cost a bit more to get OEM quality.
Kind of a formula ... the harder the part is to get to ... the more I'll spend on it to get quality :)
/ Ford 1715 clutch replacement #13
Hi!
I actually JUST did a ford 1700 clutch replacement with that same part. Worked great so far. clutch does not seem to have any issues.
Happy to answer any specific questions you may have. I did not check the gapping, and everything seems to be great so far.
