Self leveling loader. Yes or no?
/ Self leveling loader. Yes or no? #21
My Case loader/backhoe has one but I disconnected it. If you take a partial scoop and want to move the dirt to the back of the bucket, you couldn't bang the full-curl mechanical stop hard enough to do that. The hydraulics dampened the curl too much. Still, it didn't take long to disconnect so it won't take long to reconnect, if necessary, and if I can remember how. If yours is free and you can disable it quickly, go for it.
/ Self leveling loader. Yes or no? #22
I can't even comprehend that this is a question.
My book says get the self leveler.
I've used my neighbors JD ?? tractor and it does NOT have a self leveling loader (contrasted with my backhoe/loader which does)
I was carrying some "stuff" (some tree trunks of a small diameter) to the burn pile. Only way I could get the bucket level enough to hold them was to raise it.....no problem....but if I raised it much further, they'd slide off the back right onto the engine cover of his 1-year old highly UN-scratched green tractor. I do NOT want to be the first person to put a dent in the hood.
On my backhoe/loader, I can put it where I want and it will compensate (mechanical).
I would not want to be without it if I had a choice.
/ Self leveling loader. Yes or no? #23
I vote yes.
My backhoe loader has it and I like it. My JD doesn't and I have to be careful not to dump stuff out of the back of the bucket.
I can't think of any downside to having it.
/ Self leveling loader. Yes or no? #24
Sometimes doing grading or dirt work. Other than that, all positive
Can you give more specific details as to what happens as a fact of having the self leveler?
I've graded enough dirt around here BUT, my ONLY experience has been with a self leveler....so I don't know/understand the details of what the difference is. If I were to do more grading, odds are I'd opt for my larger heavier machine than the tractor that doesn't self level so I'll never have any/much experience to note the differences.
/ Self leveling loader. Yes or no? #25
Like if grading/pushing forward and coming to a dip where you have to raise up, you would have to adjust tilt to compensate. No big deal, just have to pay attention
/ Self leveling loader. Yes or no? #26
Now that's something I do frequently.
Was your hydraulic or a mechanical linkage?
/ Self leveling loader. Yes or no? #27
....but if I raised it much further, they'd slide off the back right onto the engine cover ....
...I have to be careful not to dump stuff out of the back of the bucket....
That's something I have to watch for constantly on my machine. I've had lap-fulls of dirt a couple of times. I got bars for my forks because of this.
/ Self leveling loader. Yes or no? #28
Probably hydraulic, with a mechanical linkage for position feedback . It kinda feathers out to its own curl limit. Might be awhile until I can confirm that.
/ Self leveling loader. Yes or no? #29
My M59 has the ability to turn hydraulic self levelling on and off. Its a nice feature. Mechanical self levelling is nicer. Ive owned machines with and without MSL\HSL and my preference is to only buy machines that have self levelling. Another important feature is enough hydraulic flow to run multiple functions simultaneously. The inability to lift and dump or lower and curl is a deal killer for me.
When would a self-leveling loader be a detriment? Just curious, as I haven't run into that situation yet, but am always wanting to learn something.
Mechanical self levelling works the best in my books and there isnt I time I wish I didnt have it.
Hydraulic self levelling needs correction. I also find HSL a little slower when moving dirt and adds about a second to the cycle, but it is an absolute necessity if you are loading dump trucks with soil or moving pallets. If Im just spreading a pile and dont lift the bucket higher than the hood I turn HSL off for speed.
/ Self leveling loader. Yes or no? #30
The one disadvantage that I have found with the mechanical self leveling is that it does restrict the curl back amount,
when digging into material and wanting to curl the bucket back and acquire a heaping full bucket the limited curl does not let the front edge of the bucket roll back enogh,
that said it also does not spill over the back of the bucket when lifted all the way.
Loading feed out of an ag bag were it is desired to get a heaping full bucket at a minimal lift height is it's only downfall.
You can easily see the difference between the two if both are on the dealers lot,
just curl both buckets to full dump and full curl and see how the angles differ at different lift heights.
/ Self leveling loader. Yes or no? #31
Would it be possible to disable mechanical self leveling if the need arose? Probably would require disconnect or removal of the SL links between the loader mast and the cylinder bell cranks. Then the bell cranks would need to be immobilized by some method. Probably wouldn't be extremely difficult to design this feature into a FEL.
/ Self leveling loader. Yes or no? #32
The mechanical linkage also moves the cylinder forward and backward in relation to a non self leveling loader. That's why they also used shorter curl cylinders. If you would deactivate the linkage and lock the rear pivot pin of the curl cylinder, you wouldn't have enough stroke for a proper curl and dump.
/ Self leveling loader. Yes or no? #33
Well that is interesting. I always assumed that the curl cylinder stroke would be the same regardless but I have heard several times in the past that self-leveling loaders don't have enough range in the motion of the curl. I'm wondering if it is an issue of not enough room to swing the self leveling along with full curl function. It would be interesting to do the layout for a self leveling FEL to see what's going on.
/ Self leveling loader. Yes or no? #34
Well, I should've said that it kinda depends on the design of the loader. Some will have the same stroke, regardless being self leveling or not. Others have shorter cylinders for the curl. For a loader manufacturer, it's better to maintain the same stroke and just change the ends of the cylinders.
Here is a few examples of different styles.
Non self leveling:
Hydraulic self leveling, note the smaller cylinders over the lift cylinders:
Mechanical self leveling:
/ Self leveling loader. Yes or no? #35
I noticed this on my new deere self-leveling loader -- doesn't curl back as far as my previous loader using the same grapple. For grapple work I'd say NO -- skip it.
/ Self leveling loader. Yes or no? #36
coming from a kubota b7800 with no self leveling I rented a b26 with self leveling and I hated it for the reasons mentioned above (limited curl at certain heights) I would definitely skip it.
It is something you really need to demo before choosing. free options that you hate are going to cost you money down the road.
/ Self leveling loader. Yes or no? #37
My Deere backhoe had one and it sucked to epic proportions. It limited how far back I could roll the bucket and made spilling much worse of a problem than it really was. It had a pin that controlled it and I cut it off. My M59 has a hydraulic one and I’m not a big fan of it either. Reason one I just don’t like it. Reason 2 the loader is weaker with it engaged. Reason 3 if you’ve got your grapple or bucket rolled down and try to lower it on a precise spot you can’t because the bucket is going to flip forward when you lower. Reason 4 and probably the most annoying of all is when I’m loading my dump truck I raise the loader and dump the load then I roll the bucket back up to clear the sideboard and lower the loader arms except the self level tries to continue rolling the bucket up and deadheads the hydraulics. You have to stop lowering and curl the bucket back down and then continue. With all the downsides it doesn’t even work perfect. You still have to make adjustments to keep the bucket or more importantly pallet forks level.
/ Self leveling loader. Yes or no? #38
I had tractor with standard loader and ended up replacing with self levFeling. I used my tractor for bucket and dirt and loading and unloading hay. Would recommend the self leveling very much for those applications. That was 90 hp tractor and have recently sold it as retiring from farming and bought Kubota L which does not offer self leveling as I understood. No more bucket work than have done already miss the self level loader. That being said using grapple mostly on the Kubota and agree the standard loader there works fine. My tractor with self leveling was a JD and used mechanical setup, worked very well...but it did reduce visibility some as there were level linkage on the top of the loader. Back to operate the two if possible at dealer. But if I were moving dirt or rocks only kind I would have.
/ Self leveling loader. Yes or no? #39
I'd love to have the self-leveling feature on my L3400. I've been hounding my Kubota dealer for 2 years for a kit, but so far he says it's unavailable for my little tractor. I know Branson does have a kit; why not Kubota?
Granted, I use my tractor more for fork work than lifting, so my requirement obviously is biased.
/ Self leveling loader. Yes or no? #40
A self-leveling loader was standard on my new tractor and I much prefer it over my previous loader. The only adjustment I needed to make was when dumping stone or loose material - on the old tractor I could gauge the drop of the FEL arms to meter out the material without needing to control bucket tilt. Dumping now means I need to explicitly tilt the bucket. It's an extra motion the few times it comes up, and no big deal. Just a different feel.
All said if given the choice I'd prefer the leveling option.
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
UNUSED CFG INDUSTRIAL MX15RX MINI SKID STEER (A62130)
UNUSED CFG...
2025 Kivel 48in Forks and Frame Tractor Attachment (A61567)
2025 Kivel 48in...
CLUBCAR CARRYALL 1700 DISEL GOLF CART (A62130)
CLUBCAR CARRYALL...
2015 Ford F-250 Ext. Cab Auto Crane EHC-32 1.5 Ton Crane Service Truck (A61568)
2015 Ford F-250...
