Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,821
The only drawbacks as I see it are the added weight and if you need to lift a tall load with the forks. But it looks like you could pull a few pins and remove the thumb? I am surprised fork grapples are not more common. :thumbsup:
The additional weight is minimal for the M and yes, if necessary, the thumb is easily removed.
/ Grappling fun - A Picture Thread.... #1,822
Tough call as I have neither in hydraulic but for log gathering/brush clearing seems a grapple would be best. For picking rocks, maybe a thumb. I do get by with my mechanical thumb on rocks now. My vote considering my circumstances would be the grapple.
I Have picked up Cedar trees maybe 15 foot tall with my Backhoe Thumb and moved them around to pile them up. The Thumb also makes it real nice to hold the trees up while I cut them up for Firewood. I do not have very much Brush on my property. My Situation makes it hard for me to Justify the Cost of a good Grapple. Everyone that owns a Tractor has different Needs with Different Typographical areas where they are using them. I would Love to have a Grapple but I think that it would just be sitting on the ground most of the time in my case.
/ Grappling fun - A Picture Thread.... #1,823
That is the reason I went with the fork grapple. I already owned the forks and the cost of the thumb was minimal compared to dedicated grapple.
/ Grappling fun - A Picture Thread.... #1,824
Now that most all the clearing I wanted to do is done, I can’t justify a grapple either. The thumb will do.
/ Grappling fun - A Picture Thread.... #1,825
My 1154 FEL on a M7060HDC has about 3K lifting capacity, and the EA 66" grapples eat up a bunch of that weighing in at 770 lbs. Off hand, I don't know the add-back of the bucket, but the forks have to be less so maybe only a 4-500lb penalty.... Good provocation!
/ Grappling fun - A Picture Thread.... #1,826
770 lbs. sounds too heavy. Did you weigh the grapple?
/ Grappling fun - A Picture Thread.... #1,827
You're right!! I operated from memory on the grapple weight. The 66" unit is 660 lbs. Thanks!
/ Grappling fun - A Picture Thread.... #1,828
/ Grappling fun - A Picture Thread.... #1,833
Been having some fun with the new toy.
/ Grappling fun - A Picture Thread.... #1,835
Very Impressive! Nice stone.
/ Grappling fun - A Picture Thread.... #1,836
I thought it was a smaller rock sitting on the surface. Pulled it out in one big grunt. Bent the grapple tip a bit as I had only one upper jaw tip on the rock. Heat and hammer fixed that.
/ Grappling fun - A Picture Thread.... #1,837
That is a big rock! Good job. I hope to get back to some grapple fun by the middle of July. It even makes the brush work kind of fun.
/ Grappling fun - A Picture Thread.... #1,838
:thumbsup: IT! My hole would have been three times that trying to get that one dislodged and then I would have realized that I ain't lifting with my BH and thumb. How much do you gather it weighs?
/ Grappling fun - A Picture Thread.... #1,839
Grapples rock:laughing: That is as high as it would lift, I estimate it at 3000 lbs.
/ Grappling fun - A Picture Thread.... #1,840
This is my entry in the "Big-Rock Show". It is evident that grapples can work well at plucking them out.
gg
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
832654 (A61165)
832654 (A61165)
2018 Hustler Super 104 Zero Turn Mower (A63116)
2018 Hustler Super...
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
CLUBCAR CARRYALL 1700 DISEL GOLF CART (A62130)
CLUBCAR CARRYALL...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
