havein trouble keeping my Stabilizers tight
   / havein trouble keeping my Stabilizers tight #11
Look at the telescopic stabilizers where they attach to the rear end of the tractor and there is a knuckle there. It will fold over when pushed into compression and isn't capable of carrying that type of load (or at least not very much for very long).
You could never adjust the stabilizers so perfectly that one would be exactly in compression while the other was exactly in tension. One of those things will happen before the other, and ideally you want the tension side to be happening first so that the other stabilizer goes slack but doesn't go into compression.
   / havein trouble keeping my Stabilizers tight #12
Exactly!
   / havein trouble keeping my Stabilizers tight #13
I'm not sure we've gotten to the crux of the OP's issue, which I'm not sure they've clearly explained. My turnbuckles have these keeper pins that prevent them from turning either way once adjusted.
   / havein trouble keeping my Stabilizers tight #14
I haven't seen how the RK are set up, my little Mahindra eMax uses turnbuckles with a locknut. I carry an adjustable end wrench in the tool box, after I adjust them I hold them firmly and tighten the locknut..they stay where I set them.
   / havein trouble keeping my Stabilizers tight #15
I've not seen that method used before. Looks fairly simple yet effective.
   / havein trouble keeping my Stabilizers tight #16
My first tractor- Ford 4WD 1700 - had turnbuckles with lock nuts. I did just like shovelmike, post #14, does. As long as I got the lock nuts tight it worked just fine.
   / havein trouble keeping my Stabilizers tight #17
If the IO has a turnbuckle style stabilizer, it should have some means if locking the turn ability of the turnbuckle once tightened. This should also be turn of top links. If there is not, one if the screw rods will be right handed threads, so pull it apart and take it with you to a hardware store and buy 2 nut to use as a lock nut (one for each stabilizer).
One other point, as your lower arms travel through the lifting range, tightness will vary. It is possible that this could be an issue. Always tighten to allow the swing you desire at the height you plan to work the implement (or as close as possible if a ground engaging implement).
PALLET OF FLUORESCENT LIGHT BULBS (A58374)
PALLET OF...
2007 LUFKIN END DUMP (A58214)
2007 LUFKIN END...
2021 Ford F-150 4X4 Ext. Cab Pickup Truck (A55973)
2021 Ford F-150...
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
1995 Ford 3930 50HP Utility Tractor w/ Land Pride RCD1884 84in. Brush Cutter (A55973)
1995 Ford 3930...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
